Originally Posted by NiteInDFW
I just replace the igniton switch not long ago. the old one just came apart one day when I started it. it has the "security" hex on it that was hard to find. that part is only 10 bucks so replacing it would not be that bad only thing is I just did that like 3 months ago.
Originally Posted by Scott Adams
I had to replace both the key switch and the solid state switch module mounted on the column after the key switch. That module literally did a melt down.
Originally Posted by big_tymer
hey guys iam haveing a similer problem but little diffrent i think mine is the fuel pump cuz some times she starts some time nothing? its so f in weird ill try to start it and nothing 20 min later it will start think its a fuel pump prob or may b a relay? lil help would b nice=)
Originally Posted by brentalan
Lots of posts tonight OS!
Originally Posted by cruzah
I just joined the website and its a mighty fine website if i must say...I'm having just about the same problem with my 1990 LS.
i put a new battery in and i think the anti theft came on now it woun't start and all my lights are on...anybody think they can help |
Originally Posted by 1986_MarkVII
Similar problem to the insane guy, except I have already lost it.
Originally Posted by fordtechguru
wow what a mess.. by drains 13.8 are you reading voltage??? trying amperage between the positive cable and the batt term. wil give you an idea of the size of the draw, which should lead you to a circuit capable of drawing that current without frying. if you show 25a then a smaller circuit would blow fuses or melt wiring, thus go for large circuits.. did you pull the charge lead from the alternator?? or is the case warm (indicating a short)?? since no fuses were blown and pulling them didn't stop the drain, look for non-fused circuits, i.e. starter cable, alternator charge lead, harness to ign.switch, etc... caution, when checking amperage most dvom's fuse is 20a max, a short buzzer will help with larger shorts safely, you can get one off a tool truck or maybe a buddy, when you disconnect the short circuit, it shuts up.. don't give up... also a current meter can be a lifesaver, looks like a compass, get close to the short and she swings towards the short, get over it and it dithers, go past it and it swings the other way, just follow the needle... i'll shut up now, just hate to see the car win.. lol
so far, so good... set voltmeter to a/c volts and test with engine running... across batt. terms. like before (one click counterclockwise from pictured, (sorry to be condesending, no intent) see how much voltage it reads should be less than like 100-125mv, or, take it to autozone and have it checked for "ripple".. (same difference) excess ripple or a/c leakage will kill your batt. quickly and cause a barrage of other concerns. lol keep posting..
My uncle then recommended that I let go and pull the life support on the Lincoln and just focus on my 4CV. ... |
Jelsoft Enterprises Limited.
