? How does the rear diff work in comparrison to a solid axle diff?|
Originally Posted by ONEBADMK8
Nope, its a one tire fire. See here for this demonstrated by me at our LVC meet at the shop with an 05'.
Originally Posted by IL-LS
LOL sweet!!!
That LS stock? Was there bleach on the ground? |
Originally Posted by BIG CELO
Darn Whats under that hood for that LS to peel out like that WOW
Im always afraid to torque the engine up like that while on the brakes! How high did you have the rpm's? I have held the brake down and got on the gas a little, and the car squats (which is odd in itself??) but im chicken to get on it any harder!
All stock. Its funny if you watch when the camera pans back to the smoke and you can't even see the Eckerd drug store across the street. It was an amazing amount of smoke.
One more question if you have the advance track off and you peel out the way the mpg shows wouldn't you break up something on the advance track system or would it be ok?? I'm going to watch the video again it looks sick!!
I would think if it was OFF you would override it, and be okay.. Cant imagine what it would do w/ it on.. besides reduce engine power, apply breaks, man it could be a mess?
I would like to try it but I'm scared im going to get some check something light and I have to take it to the LM Dealer to get serviced!! The car in the movie sounded like it had a modified cat back system from ONEBADMK8 I may be wrong but ONEBADMK8 did say it was all stock!!
The only thing we had done to that car is an experimental intake that we are working on. Thats why it has a slight "growl" from under the hood.
Were just in the playing stages right now. I will post results when finished for sure.
Originally Posted by mcafferty
nice but it was over a curb could this be done on level ground? lol
Originally Posted by Pete02LSE
Yeah...I noticed that too. Seems like concrete would have a more porous surface and would be easier to power brake on. Dunno if I would try that in our LSE on asphalt but...it's cool nonetheless.
Originally Posted by Dutch
If the weight of the car is even on both sides, and the planets are lined up just right, and you stayed at a Holiday Inn the night before, even an open differential can lay two patches. It's uncommon, but definately possible.
IF you really want to know if your car has a limited slip differential, lift up the rear end and turn one tire. If the opposite tire spins in the same direction, you have limited slip. IF it spins backwards, you have a peg leg. |
Originally Posted by Motts
any v6 burn outs, is it even possible.. punch it, pull ebrake.. lol
Originally Posted by rocket5979
So does anyone have a locking or limited slip diff in their car, besides what is controlled by the TC??? I wonder if installing a LS diff would mess with the TC? I would think it would not hinder the TC just because what a LSD would do is more or less what the TC would do in a similar situation. Lose traction while accelerating and lock the rears together to gain traction versus applying brake to slipping side thus putting power to the opposite side essentially creating a simulated locked diff. Am I missing something? I am sure there are others out there that know alot more on this than I.
There was no limited slip differential offered for the LS, and it would work independently of the traction control. A limited slip differential is a mechanical device with clutches that ensure the axles spin at more or less the same rate. Traction control uses the brake and, under extreme wheelspin, cuts fuel to limit spin. If you have limited slip, you can still spin your tires, they'll just both spin instead of one. Traction control would act by applying the brake to both wheels, and not just one. The two systems are totally independent and could be on the car without any problems. I don't know of any limited slip unit that would work, though. Maybe the Jaguar S-Type R has one...
Originally Posted by JohnnyBz00LS
I know of only one person who started to install a torsen LSD into a boneyard diff case for his LS. IIRC, he started w/ another Ford carrier from a Corbra, but there were some tricks he was going to have to do to get it to fit (can't remember what those tricks were). Overcome by other events, he passed this project onto the west coast LLSOC group to finish (still waiting).
I seriously doubt that when the TC/AT system detects both rear wheels spinning that it applies brakes to BOTH rear wheels. I think it cuts engine power instead. I know for sure when I stomp it in the snow, there is no massive tug-o-war going on between the engine and the rear brakes.
Since off-the-line torque is not the 3.9L's strong suit, the real-world need for a LSD....... for drag racing purposes......... really isn't there.
Jelsoft Enterprises Limited.
