Originally Posted by MonsterMark
$600 for a 'dry' kit will get you in the 12's with a 125 shot. Wet kits tend to pool and blow intakes.
Originally Posted by sho89mtx
what the diference btwn a dry and wet kit, the amount of shot? also it it illegal to have on your car?
Originally Posted by 95LSC32V
Basically with a dry shot you trick the MAF to adjust for more fuel while with the wet shot you shoot fuel with the nitrous. Both setups have their advantages but the dry shot is easier to install and more commonly used on the 4.6 DOHC. You will need to get some colder spark plugs. I think the Autolite AR103's are perfect for a 100 shot. Gap the plugs at .035. Also you will need a Walbro 255lph fuel pump and make sure your fuel injectors are in decent shape. On top off that you should get a tune (chip or dyno tune). You might want to retard your timing a bit and make sure the A/F ratio is cool while you are spraying. If your car runs a 14.9 or 15.0 I could see it dipping into the 13's with a 100 dry shot which is like 75 at the rear wheels.
Originally Posted by outkast
that headhunter car is that geno's or who's is it and what is all done to it?
Jelsoft Enterprises Limited.
