Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Leaking Rear Brake Caliper!!!!!
Posted by: surfaaron
My rear caliper on the drivers side of my 87 mark is leaking. It seems to be leaking from where the bolt that holds on the e-brake cable goes in to the caliper. Can I replace the O rings or do I have to replace the cliper. If the O rings can be replaced where can I get them at. Thanks for any help.
Quote:
Does any body have any info to help me out. I cant believe with all the mecanics on this sight no one has any info for me. Throw me a bone. Thanks for any help.
Posted by: talonlsc
Just replace it..save the headaches for something else
Posted by: WALT
not worked the rear calipers in a long time
but off the top of my head I would think that there O rings
around the shaft for the park brake lever --
have suspicion that it would be much harder to try to get that all
apart ( piston / lever / shaft ) to replace seals ( then you have
to try to find some seals and will just have to do a "match "
at the parts store, etc etc ) --- so would be much faster
and less fustrating to just replace the caliper assembly.
good luck
Posted by: American Air-1
Most calipers are a piece of cake to do, but that one is a little tricky. I agree to just replace the caliper with a rebuilt unit and be done with it. If the funds are available, it "would be best" to do the other side as well.
Quote:
Any idea where would be the best place to get rebuilt calipers and the cheapest?
Most any Autozone or Pep Boys would have what you need.
Posted by: WALT
If price is your only concern then Advance, Carquest , Autozone, Pep boys
are all pretty equal -- a few phone calls will get you a price check then just
go with the best price --
Tapety na pulpit, wallpapers:Car Insurance:Novela historica:Unblock Myspace:Mortgages
