Originally Posted by ONEBADMK8
Never heard of that with a Nology wire in my life. What do you mean exactly? Is the wire "snaping" into position then popping up?
The rubber part may be a bit longer then the others, right on the end. Compare it to one that sit normal. If its too long then cut the difference off with a fresh razor blade so its the same length as the one that sits right.
Jelsoft Enterprises Limited.
