Originally Posted by blk04lse
Dutch - where can you buy a new LS V8 for $33K?
I agree the 4.6L is not the most reliable; however the 03-04 Mach 1 motor w/ forged internals and the 03-04 Cobra motor are the exception... As far as adding a supercharger, turbo and/or nitrious to the 3.9, unless the motor is torn down and prepped for a power adder, the life span will be short lived... |
If the transmission is good enough for the 05 GT, but is the weakest link on the LS? I would guess the rear end is the weakest link...
LS v8 can handle up to 400 hp... do we have forged internals? |
Originally Posted by Quik LS
it's not the same trannie in the GT. The LS engineers thought that the trannie would be good for 'around' 340hp or so....
No problem... Funny though, whether the 5R55N or 5R55S transmission, we all seem to have similar issues w/ the trannies...
So, from what I am gathering, it appears others feel the LS could have used a little more H.P. under the hood, especially w/ the S4, CTSV, G35 Sedan and AMG on the road... Has anyone on this forum or other owners that you know of spoken w/ Ford Racing, BBK, Holley, Edlebrock, Steeda, Anderson Racing etc., for a broader selection of aftermarket parts, such as a rear end gear, axles, stalls, emission legal/yet modified cams, upgraded heads, mass air meters, etc? |
Originally Posted by dropped74
Always want more power. What ever happened to the guy that was working the Turbo!!!!????
Originally Posted by SurfjaxLS
I've also been wondering about him, maybe a twin turbo is still just a dream.
Originally Posted by eL eS
jeez was he moving the exhaust. I know you are a serious guy but are you serious... it was in the back.
Originally Posted by Dutch
Here's the math I did when I bought my used LS.
MSRP: $40,600 Invoice: $37,300 Rebates: $6,000 + $1,000 Your price: $30,300 So a new LS V8 would've been $30,300 assuming you paid invoice and financed through Ford for the extra $1,000 rebate. I don't know if the rebates are still that high now. |
You can always regrind the cams. I would bet nobody's done it yet, though.
Interesting. Not great gains, but he probably had to do alot of guessing as to which cam provide would be best. That guy's a real trail blazer. Did he have any sort of chip or dyno tune to ensure he got the full benefit of his work?
1. Besides the tire and spare, where can we lose weight w/out diminishing the integrity of the car? On the car, not the driver... ha ha ha
2. $4000 - $5000 + for a supercharger is ridiculous, especially when you can get a Powerdyne (6 lbs) under $2000 for a 5.0 L Mustang... An option is the pick up a used supercharger head unit, but fabricate the plumbing and brackets.... May want to increase the fuel injector size (if available) and install a fuel pressure regulator...
3. Only 36 hp out of port heads and custom cams???? Man, that is where NMRA Mustang engine builders/modifiers come in like Ed Curtis or Rick Anderson, where they can port and freshen up the heads, and create custom cams that are built to match the flow rate of the heads (they have software that spits out the cam specs based on all of the variables of the moto and setup of the car - they do make emissions legal cams too).
4. Unless I am mistaken, I do not believe there are Stalls out there for this car... Are there steeper rear end gears? Will the 05 GT aftermarket gears fit? And we do not have limited slip?
Does anyone know what they cost?
hmmm turbo or sc?
Originally Posted by Putter-GLHT
Not to highjack the thread, but how is the getrag 5sp used in the v6 models? I've been serioiusly considering my next project using a 3.0 v6 5sp LS with a turbo....
I know quite a bit about turbocharging and would very much have been wanting to play with a 24valve 3.0, an awesome motor by any means. I figure a solid 400hp on street gas should be a walk in the park. Anyone know where I can find more info on the manual transmission, as I could not find a search button in the forums. |
Originally Posted by 2k2ls
there was the one ls (black) that was turbo charged. It ended up blowing after over-boosting (or something). I think it was here on the forum.
I think onebadls is the guy we need to talk to about turbos, or at least his project.
http://www.lincolnvscadillac.com/sho...ght=twin+turbo |
4.6L is a POS. When you talk money, don't forget that, although the sticker may say $42k for a V8, you shouldn't have to pay more than maybe $33k to buy one.
That being said, more power would still be good, just not through the awful 4.6L. Better choices would be the naturally aspirated or blown 4.2L Jaguar engines. They would actually fit under the hood (unlike a 4.6L) and would bolt up to the tranny (unlike a 4.6L). Lincoln should at least try offering the blown 4.2L on a limited number of LSes. Because everything would (seems like it should at least) bolt right in, it would probably be pretty cheap. |
Originally Posted by rocket5979
I have seen SOHC 4.6's with the stock longblock push out 420+ rwhp on a Kenne Bell 1.7 supercharger @ 9# boost and hold up to it for a long long time with a good tune.
4.6 Is definatly one of the best engines ford has ever made. I work on these things every day and I've only seen 2 4.6 engines fail. One 54,000 miles on factory oil and filter, and the other in a police car with a loose drainplug driven with no oil until lockup, then cooled and driven to the dealership with no oil later that day.
Now, while working on both engines, I almost wonder if the 3.9 isn't loosley based off of a 4.6 if not entirely...? To me the eng config looks like a severely destroked 4.6 4v with a shorter deck and a more expensive intake. |
I've seen a stock 3.8L V6 do the same thing with turbos...Yes, there are kids running around with 10 second V6 Mustangs.
Anyway, my comments toward the 4.6L aren't based solely on reliability, but on having a crummy torque curve with no bottom end. When my V6 Mustang was in the shop once, the dealer gave me a GT loaner. I'm sure it was a lot faster than my V6, but it sure didn't feel it. The problem was the lack of torque. Same thing with the Marauder. I've driven Crown Vics and Grand Marquis, and a handful of Mustangs with the 4.6L, and I just can't stand that engine. |
BTW- I know that Jaguar made an engine that also displaces 3.9 liters, but is it really the same engine as the 3.9 LS engine through and through? I tried to look that info up about 5 months ago but didnt come up with alot of information.
Yeah, it's the same engine.
http://www.jagweb.com/aj6eng/v8_performance.html The LS 3.9L is a slightly cheapened Jag 4.0L that has had the bore reduced .05mm for marketing (so Jag buyers get a bigger engine). Also, the Jags have variable valve timing, which the LS didn't get until '03. On the lack of bottom end, I hear you when you say it's ironic for such a comment to come from a 3.9L owner. However, the LS's 5-speed tranny does a great job at compensating for that. What's 1st gear on a 4R70W? 2.4? 2.4 x 3.27 rear = 7.85 torque multiplication in 1st gear. For an LS, it's 3.25 x 3.31 = 10.76. The 3.9L in the LS feels a lot bigger than it is. I'd like to see a dyno chart of it. It'd be interesting to compare area under the curve to a Mustang 4.6L. |
only the block is shared with the Jag.
Most of the sharing between LS and Jag is the DEW98 chassis. http://www.designnews.com/article/CA86948.html |
Jelsoft Enterprises Limited.
