Originally Posted by jdsimons
I was wondering do they completely shut off to whisper quiet or is it just slightly lower.
Originally Posted by MikeB
Not sure about the LS, but some of the old Alpine amps went into a reduced protect mode when they had saw a lower ohm load. Such as a speaker going bad.
The speakers may still play at a lower volume but when the volume goes up the change in ohm load could trigger the protect, which would reset if the amp was turned off and then on. That one speaker is more than likely your problem. |
Are the door speakers still factory?
Next step is taking the door pannels off.
I'd start with the rear driver then the front. Disconnect the speaker and see if there is any effect on the volume of the others. You may have to turn the car off then on to reset the amp. |
Once you get the door pannel off and the speaker removed (unplugged) the radio should play at the higher volume if that speaker was the problem.
If you remove the speaker and the radio still sounds funny then more than likely that speaker is good. This is a trial and error process, but each door shouldn't take any more than 15 minutes or less once you get the first one. Just a sugestion, I would do the driver's side front and back first and leave both the speaker disconnected when I reset the radio. If the sound is still low after you unplug each speaker individually, (with turning the car off then on before checking) then the problem is with the amps or the wiring. 99.9% of the time if the speakers are good then it's the amps. The wiring is usually good unless someone has been jacking with it. Someone in this forum did a great step by step with picture door speaker removal. I cant seem to find it now but if you post a thread they will come. |
99.9% of the time if the speakers are good then it's the amps. The wiring is usually good unless someone has been jacking with it. |
Originally Posted by triniti
I appreciate the info Mike. I'll give it a shot and replace the door speakers while I'm at it.
I just noticed you said amp(s). Is there more than the one main one? If so, where can I find it/them?
Jelsoft Enterprises Limited.
