Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
VCRM??? and who has one
Posted by: NickT88LSC
95 Mark VIII, a/c stopped working and no cooling fan, from reading other post seems like that VCRM correct??? I checked fuses-all good, swapped relays around - no change. I checked low pressure switch-has voltage, jumped across it-no change
So does anyone have a known good one???
Also, how is the connector held to the module??? By a center nut like ECM'S??? If so, what size, cause I tried some sockets and nothing seems to fit. I tried also getting the lower bolt out of the control module to bracket and no luck, bolt and nut are spinning.
Posted by: jamie97lsc
i have a bunch and the plug is held in with a center bolt, its one of two sizes, they used 7 mm or more commonly 5.5 mm. the bolt holding the module to the bracket is an 8 mm bolt and if you have to just break it, if all it does is spin, or try to hold the back side with vice grips and loosen the bolt.
Quote:
Cool deal Jamie, let me know how much and payment accepted. Paypal???
I think I went down to like 6 mm and still did not work, so I guess 5.5 it is, I just figured unpug the connector and plug in the new one to make sure works then.
Posted by: thaywood
Hi! Have you got any more of these VRCM's? And if so, how much $$ and when can I get one? I'm having a hard time finding one.
nick pm sent.
Quote:
yes i do have plenty more but if your mark VIII is a 1996 then i cannot help you. if it is a 93,4,5,7, or 98 then i can help. let me know what year it is.
Posted by: CobraStar_LS8
This is why I have 2 extra good ones for safety
vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2010 - Created by Stefan "Xenon" Kaeser
