I've considered drilling and threading a hole all the way THRU the crossover cap, so I dont have to pull the cap out to "bleed air".. just loosen the bolt and let it bleed out.
Kinda like the bleeder bolts on a some Chevy thermostat housings. |
I get the idea like the bleeders on the Chevs but then you will have to worry about an even smaller bolt getting stuck/corroded in there over time too, no?
Plus as you mentioned the cap is quite thick, so the bleeder screw/bolt would have to go somewhere else to make it the high point in the system?
Think a large bleeder screw off a brake caliper would work? Wouldn’t look as nice but good idea with the bleeder though.
My crossover needs to come out so I can repaint it anyway, Myco is yours pritty rusty? |
I think the main place people run into trouble is they don't clean out the 1/4 drive opening,.
edit: the nut right now is ruined. I've demolished it trying to get it out. |
yeah and that braise looks cracked to me. get another crossover.
I have no idea what you are on about, there.
Sounds like you still have air in your system.
Clogged alternator. I have no idea what you are on about, there. |
Haha... That's better!
Some of the best tips I've found are from XLRVIII, in this thread: http://www.lincolnvscadillac.com/sho...hlight=coolant |
yea got it replaced almost entirely still gotta get a couple clamps on. found out when i torqued it down the seal had fallen on the wrong place..60$ to ford
One of two things is wrong.
1. Not Burped Correctly 2. Smoke the head Gaskets |
ing EDU: on how to burp. Apparently you are the master of it. I just heard from a guy on another forum to leave the crossover cap off overnight as well as the overflow cap and then refill in the morning.
dude...|
Easy
![]() ![]() ![]() dude...The MOST important part is to geta funnel that is the right size so it screws into the crossover but not fall out or restrict flow... Lift the front of the car up about a foot... Take of both caps and start filling through the crossover until the level is full in the reservoir Put reservoir cap on Continue Filling until the crossover is FULL and that includes the funnel Then start the car and just let it run... All sorts of bubbles will come out and just let it run until they stop, then I'd just let it sit and cool down and run it again... If that don't work your head gaskets are boned... |
Question: I flashed the ECU to a 98 mark when i bought the car. Could that have caused this issue?
I'm wondering why you're overheating on the highway, that worries me. I would never overheat on the highway with the bad fan, only in traffic. |
) and fill the funnel so that way when the bubbles escape, it sucks in more coolant.
I know what your sayin Tommy.
Myco said he had the coolent system pressure tested too. If he had a leak somewere it should have been found during the pressure test. That includes a head gasket. |
vBulletin Copyright ©2000 - 2010,
Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2010
