Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Just installed K&N 9" cone air filter
Posted by: LuvMyCTS
I just installed the K&N 9" cone filter. This isn't the kit made specifically for the CTS but accomplished the same thing and is a LOT CHEAPER. All you need is the filter which you can order for 40-50 dollars. It's part number RE-0920. The filter is a standard 9" long cone filter with a 3.5" flange. If you disassemble the stock air-box, you'll find that the inlet inside the box attached to the MAF sensor is exactly 3.5". Everything fits perfectly! I pushed the filter onto the inlet and tightened the metal collar around the flange. Their seems to be enough support from the half of the airbox to keep it from flopping around. I'm going to see if I can cut the bolt anchors from the unused half of the airbox so I can use those to give further support this weekend. After installationg, the first thing I noticed was the much more throatier sound. Under light to normal throttle, there is no noticeable difference in performance or sound but once you tap the throttle a little more, a very throaty engine starts to roar. I can feel a little performance gain (maybe 7-10 HP) using my patented Butt-O-Meter horsepower measurement device, more pressure on my butt from the seat when exactly = more horsepower. I can now perform a burnout without dropping the clutch or fanning the clutch. I wish I could post pictures but I have no digital camera for now. Once I get one I'll be sure to post them up in this thread.
Posted by: ModPWR
Are you saying that you have a manual CTS ? Man, I want ONE !!
Posted by: CaddyKiddCTS
How much of a noise differnece is there after adding the intake. Do you get a more throaty sound.
Posted by: jackal
who did you go thru for the filter ?
Posted by: dpkshafer
Quote:
Yes, there is a 6 speed manual CTS and I have a 2006 with a 2.8. Got this in April of last year and they were giving them away as there is not much demand for the manual model.
Quote:
Just got my K&N cone filter installed on my '06 CTS w/2.8 liter and it is very nice. Definite increase in horsepower and a nice little rumble to go with it. Well worth the price, now if I could figure out how to tighten the ride a little.
Babb Fest:Buy Anything On eBay:Unblock Myspace:Bleach:Credit Cards
