Hello All you Lincoln T/C owners,
I have a 98 Lincoln T/C. I believe my blending door has gone bad. When I turn on the A/C the compressor is working hoses ice cold but the inside blows maximum hot air. I can hear the vacuum actuate the door but blows hot air. I changed out the climate control and same problem. Other posts recommended disconnecting the battery to reset the computer. Did that and still same results. Someone recommended the blending door. From what I have gathered it is WAY UNDER the dash. Open for suggestions and directions to check or change out this component. I can just imagine what it would cost at the dealership. Any and all help is welcome. Thanks again-Mclintock
Posted by: evillally
Yep. That's the blend door alright. Here's an article from a Panther owner that might help you and give you an indea of what to expect:
