Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Mark VIII 1/4 or 1/8 mile Trophy Case
Posted by: mespock
LvC Mark VIII
1/4 or 1/8 mile run
Trophy Case
I was asked to make an official Mark VIII 1/4 or 1/8 mile Thread
This thread is dedicated to LvC members accomplishments at the track.
This thread is for only posting times:
Please post pics of your timeslips whenever possible or list all the
times and mph on the slip.
Please do not just post times if you do not have all of the times to
back up your run.
Please list your mods at the time of the run.
Members should refrain from posting comments which include post
like wow, nice, cool, etc... or any criticism.
If you wish to have discussion on a members run, please contact them through a PM or do this in a separate thread. I want to keep this thread to the posting of times. Think of this as a LvC trophy case.
If anyone notices any abuse of this thread please contact me and I will clean up this thread.
Posted by: 98CobraStarLSC
1998 Mark VIII LSC - Torr. Red
US41 Dragway November 2, 2008
Reaction time - +.5150
60 ft - 2.03
1/8th mile - 8.8011
1/8 mile mph - 80.62
1000' - 11.4090
1/4 mile - 13.6201
1/4 mile mph - 101.97
98CobraStarLSC - 13.62...101.97...2.01...98'...281...N/A...4.10...
Mods in Signature
Posted by: Burbank98lsc
1998 Lincoln Mark VIII LSC
US41 dragway November 2-2008
Reaction time .... +.0209
60 ft .... 1.615
1/8 ET .... 7.21
1/8 mph .... 94.57
1000' Et .... 9.45
1/4 ET .... 11.32
1/4 mph .... 120.64
My mods are:
Forged bottom end
Vortech S trim @ 11-12 psi
4200 stall lockup converter
4.10 gears
Methanol injection
Bolt ons and blower supporting mods.
Here is the time slip:
Posted by: Sergmark
Ok Heres my times from my 98.
Stock ?? not sure. I have done nothing but something may have been done to the trans.
Posted by: driller
R/T: 0.0720
60': 1.8954
330': 5.5416
1/8: 8.5728
mph: 81.04
1000': 11.1966
1/4: 13.4169
MPH: 101.74
Pro-M 85mm MAF
K&N RU3480 Air Filter
Intake silencer/resonators removed
Meziere Electric Water Pump
Custom Intake Tube
Tru-Cool MAX 40,000 GVW rating Transmission Cooler
SCT Performance Chip
Performance Distributors LiveWires - Spark Plug Wires
MotorCraft AWSF-12C Spark Plugs
HyperTech #1011 - 160 degree thermostat
DeMolet DenseCharger Cold Air Intake
Cam Shim
Billet Adjustable Fuel Pressure Regulator
Fuel Pressure Gauge
Walbro 255LPH Fuel Pump
LMS PROPOLY polyurethane carrier bushing kit
Hooker MaximumFlow Mufflers
DynoTech Engineering Metal Matrix Composite Aluminum Driveshaft
26x9.50-16 Hoosier Quick Time Pro D.O.T. Drag Tires
Performance Distributors Screamin' Demon Coil Packs
Steeda UnderDrive Crank Pulley
SCT DynoTune
Kooks 3/4 Length Jet-Hot coated Headers
SCP Solid Motor Mounts
Flaming River Billet Steering Joint
Modified Intake(Radiused/Polished/Coated)
Detroit Truetrac gear type limited slip differential
Motive 4.30 ratio Ring & Pinion
Rear Torsion Brace
Front subframe Bracing
Dunlop Racing 5.50 x 16 front tires on 16 x 4 Aluminum rims
Rear Strut Tower Brace w/ integral amplifier shelf
Ford Racing Performance Parts 24# injectors
Blue Oval Chips Stage III 3800 stall Converter
Custom 2-1/2" SS dual exhaust setup w/ Electric Cutouts
Custom Rear Subframe Bracing
ASHAM8 air suspension adjustment module
SCP Short Rear Sway Bar Link Kit w/ Polyurethane Bushings
Bilstein Rear Shocks and new improved shock mounts
Addco 1-1/4" Rear Anti-Sway Bar
DirtyDog Performance Transmission
Posted by: vr4
60'....2.312
1/8...9.364
mph..78.85
1/4...14.355
mph..98.23
mods...
j-mod no lower spring
3.55 open rear
agsf-22-fm plugs
05 mustang GT mufflers
stock exhaust crushed to half its normal small size
ill have to dig thru a pile of a couple hundred timeslips to get pics.
Posted by: Lux
I hope its allright to post this as my car was 100% stock and no mods when i made these runs, if not feel free to wax it.
1997 Mark VIII - 1/2 tank, spare tire/jack, spare belt & breaker bar in the trunk, 58,125 miles, entirely stock with new motorcraft plugs + fuel filter on kuhmo ecsta tires. Easy on the first run as it was my first time on the track with it, second time i gave it the go. I've got pic of the slips at the house.
Some altima
that had a pretty
valve cover ---------- VIII
R/T - .697----------- R/T - .536
60' - 2.448---------- 60' - 2.353
330 - 6.782-----------330 - 6.597
1/8 - 10.340----------1/8 - 9.997
Mph - 69.72-----------Mph - 72.49
1000 13.353--------- 1000 - 12.901
1/4 - 15.937----------1/4" - 15.38
MPH 87.63------------MPH 90.89
Toyota Tundra lol ---- VIII
R/T - .135----------- R/T - .347
60' - 2.445----------60' - 2.202
330 - 7.034----------330 - 6.331
1/8 - 10.831---------1/8 - 9.680
Mph - 64.75----------Mph - 73.68
1000 14.068---------1000 - 12.529
1/4 - 16.764---------1/4" - 14.945
MPH 84.51---------MPH 93.37
Update.
Posted by: driller
Well that didn't last long.
R/T - 0.017
60' - 1.856
330' - 5.405
1/8 - 8.372 @ 82.79
1000' - 10.944
1/4 - 13.113 @ 104.31
Posted by: MercuryLs
My 1994 Lincoln Mark VIII times:
OFF BOTTLE
13.2 @ 106mph on a 2.0 60'
- new(er) 4.6 DOHC
- 96-98 Cobra Cams
- Stock Mark VIII intake
- Underdrive pulley
- E-Waterpump
- 80mm MAF
- free mods
- No cats w/ an Electric cutout
- 255lpm fuel pump
- 24lb Injectors
- 4r70w Tranny w/ a Shift kit
- B&M Holeshot 2500 stall
- 3.73 gears w/ posi
- 255/60r16 Mickeys
Posted by: kustomizingkid
First ever time at the track and I'm overall pleased... my tires were junk... but definitely a good starting point.
Tuned
22c Plugs
Terrible 225/60/16 tires
Rt .877
60ft 2.35
330ft 6.84
1/8 9.84 @ 73.66
Posted by: XLRVIII
low et for the night
RT .491
60 2.24
330 6.34
1/8 9.69 @ 74.15
Posted by: htrdlincoln98
Best run to date Na Was this weekend
Also is the best ever nitrous run to date. More to come on that i'm having issues with the tuner.
Car mods:
3.73's
k+n panel filter
Stall Converter
Trans go Reprogrammer
IMRC delete
Egr delete
air pump delete
Magna flow 4" mufflers
Stock Lsc piping
180 Tstat
sniper tune
245/50/16 bfg g-force sports
Zex kit(optional)
Posted by: kracker
98 LSC
RT---------- .2559
60FT------- 2.1803
330FT------ 6.3410
594FT------ 9.0892
1/8 -------- 9.7021
MPH-------- 73.42
94
RT---------- .0573
60FT------- 2.2096
330FT------ 6.3068
1/8 -------- 9.6387
MPH-------- 74.22
Posted by: Staffamerica74
r/t... .550
60'... 2.202
330.. 6.347
1/8.. 9.688
mph.. 73.40
1000. 12.596
1/4... 15.058
mph.. 93.73
Not sure why this car is so damn slow....
Car mods:
4.10s
k+n panel filter
LMS exhaust
sniper tune
255/45/17 Avon Mtech 25psi in the rear 40psi in the front
No spare tire
13inch cobra brakes addco rear 1 1/4 bar...(things that probably slow me down a bit)
Posted by: mespock
back up your run.
Best NA run 60' to date.
Car 7042
vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2010 - Created by Stefan "Xenon" Kaeser
