Originally Posted by gadget73
There should be one under the hood on the emissions sticker. Mine is on the fan shroud.
Try hooking a code reader up and see what it tells you. It might point you in the direction of the problem. You might have a bad TPS sensor. If it isnt working, the car will usually stumble badly on opening the throttle. |
Jelsoft Enterprises Limited.
