Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Loss of uphill power with engine noise
Posted by: 94PgherConti
1994 Conti Exec with only 107K miles.
NOTE: The check engine light is NOT on !!
Not sure how to expalin this noise, but going uphill (or even level with very hard acceleration) the engine emits a sound like a quickly deflating balloon.
Not sure what "valve chatter" is or pinging really sounds like, but deflating ballon (when left go into air) is best analogy I can think of. Another is the sound when holding your tongue loosely against top-inside of roof of mouth behind front teeth and humming and forcing air to vibrate tongue ???.
Also, both my wife and I verify a NOTICEABLE loss of power going rather steep and short uphill in our residential area (not high speed).
Am I screwed?
Posted by: Glorywagon
Am I screwed?
Check the exhaust. Sounds like it might be plugged up. Maybe a bad cadilac coverter ( not sure of spelling Sorry) I had it happen on my 89 TC the Cats. come apart and plugged up my muffler. About drove me crazy till I found it. Had to replace the Cats. and the muffler at 110,000 miles.Sounded like someone stuck a banana up my tail pipe and power lose on hills. Took it in for a tune up didn't help. changed fuel filter didn't help. i had no check engine lights on. So I unbolted the Cat's and took it for a drive Wow ran good. So I replaced the Cats. and sill had the same problem . So then I cut the muffler off and it run fine. So I replaced the muffler. Zoooom.
Posted by: MichiganTeddyBear
might be bad cats as mentioned.. or a collapsed pipe in the exhaust.
on pre-96 vehicles, this usually does NOT throw a code, as they dont have downstream o2 sensors, only 96-up (obd-II).
try disconnecting the flex pipe from the exhaust/cat pipe and seeing if there are any cat parts floating around. even take it for a drive, that will let ya know if the muffler, or something downstream from the cats is plugged.
?? - The cat / muffler issue would cause the engine noise as well?
Posted by: Frat-man-du
Yes, the engine is having to force exhaust out and the hissing is symptomatic of a plugged exhaust.
