I have 75K~ on my 02.
Little history of what has been replaced: 2 weeks ago they found 7,8 misfiring they replaced 2 coil asy- 2 spark and 1 gasket valve. In Feb when I had 70K they found #4 misfiring. And replaced 1 coil, 3 sparks, 1 gasket and 2 boot-ignition. So it seems like they replaced the v/c gaskets each time. from the invoice numbers it seems like both sides have been replaced. (XW4Z-6584AB, ""BB) I don't know if its about the $$$, I mean I have a deductible so all they are getting from me is the $100. Thanks for the advice guys, I def will ask them why they are going bad so quickly -2 weeks-. There is one common element that I do recall that led to this CEL and the previous one, is that I had the RPM up briefly to around 3K-4K. (just spirited driving, no drag racing, ever). |
You can definitely control your temper better than me, too. It's unfortunate that they were such sh!tholes about the whole thing.
Jelsoft Enterprises Limited.
