R1 Concepts has a nice price on Rotors for LvC members. Check out the thread in the Mark VIII forum.
The warping or uneven braking comes from the heat build up while braking.
Heat continues to build while the brakes are applied. Pumping the brakes while stopping will drastically lower the rotor temperature even if only momentarily greatly avoiding warping. Having your brakes turned will get rid of the uneven braking. You may continue to turn (Machine) your rotors many times but never go beyond the minimum thickness stamped on the rotor. |
Jelsoft Enterprises Limited.
