When you say it bounces off the rev limiter do you mean it instantly redlines to 7000 rpm?
| I would doubt that an ABS sensor would do all this but there is a way to find out. Disconnect it. With no signal from that sensor, the ABS system will disable itself entirely. |
| The codes for a cam/crank sensor kinda throw up a red flag. Those are both used in the ignition process to determine when the COPS deliver their energy to the spark plugs. |
| Water in the trunk means they probably left your trunk open and it got rained in. I would be taking the car to a dealer (a reputable one if you can find it) right about now and have all the electronics diagnosed. The way I see it, this is now well beyond the abilities of a DIY mechanic. |
AdvanceTrac uses a yaw sensor to detect yaw, not the ABS sensors (at least in the 2nd Gen cars). I can see a flaky ABS sensor causing many seemingly unrelated problems, though.
The misfiring COP on cylinder #4 often results in a false ETC failure code (evident in an ETC FAILSAFE message and severely reduced power), but that's not possible on 1st Gen cars. I suppose it's possible for a similar false code to happen on a 1st Gen, but I've not heard of it. As for the water in the trunk, the first thing I'd check are the drain lines for the moon roof (I've forgotten if you have one). My '06 has one on each side, running down the C pillar and along the quarter panels to drain fittings behind the bumper cover. They're fairly good sized (around 3/4" OD, IIRC) soft rubber lines, so they could carry quite a bit of water into the trunk if they've popped loose. BTW, are you still hassling them poor college boys? ![]() |
Well... the car is back with a completely rebuilt tranny. $1400 in parts and $1000 in labor. The day after I got it back, the CE light came on so I swung into Autozone and they pulled #4 and #7 cylinder misfires; which I expected. Bought a couple COP's off ebay the other day and installed them. That took care of the sputtering.
But, the car has a strange vibration at 1500 rpm's in both drive and when the tranny is not engaged. I'm not overly concerned as it's more annoying than anything. And... the AdvanceTrac light still blinks. I'm wondering if the first shop bunged anything up with that when they ran the car on the lift??? At least I have the car back. |
i know you at least have your car back now but i would be super pissed if after all that money was spent on fixing it it still wasn't working how it should. did they guarantee the work on the labor?
I called my CC company and openned a case with them on the basis that the work performed on the car did not fix the original problem. They issued me a temporary credit pending the resolution of the case. I also asked the second tranny shop (the one's who rebuilt the tranny) to write up a statement on what they found as the problem and what they did. That, along with a narrative I'll write up should help the case. I'm also going to forward a complaint and request a refund through the first tranny shop's corporate HQ. Worst case scenario is that I just end up paying the CC company if they don't find in my favor. |
Checked your brake fluid level lately? Might also be a good idea to slide under the car and make sure all of your wheel sensors are plugged in.
Vibrations are always hard to track down but start by checking the motor and transmission mounts for loose bolts. |
I've had a pestering ABS problem for a while now. Every so often, the message center would tell me to check the advancetrac and throw the light on, but would go away on restart. I've also noted that I could get the front left wheel to lock which would mean an ABS sensor might be on the way out. I'm wondering if it finally failed.
My neighbor is a mechanic and he brought home a SnapOn diagnostic scanner so we could go through the car thoroughly and see what the advancetrac issue was. I went over there last night and the cartridges for the 96+ vehicles were missing so I didn't get anywhere with that. If he can't find them, I'll bring the car to FLM and have them diagnose the advancetrac. I'm going to go through the car good and check all the sensors on the wheels, fluids, plugs, etc. The car is due for an oil change soon so that'll be a good time to devote a day to the car. |
i've had that advancetrac problem myself (on and off). it might be just dirt on a sensor or something but it usually goes away. not sure what it really is but it goes away
Jelsoft Enterprises Limited.
