Is there a difference between the cabin filters between 00-02 & 03-06? They seem to be separated on alot of sites.
Posted by: rickztahone
i believe they are indeed different. ask Max--->
he would know for sure. or Ken as well
Posted by: gcwimmer
Yes the 1ST gen have a corner cut off and the 2ND gen are true square/rectangle.
Posted by: Eric0508
thanks guys, i'll just make sure to order the year specific one
you guys are the best!
Posted by: jwolsen
I just replaced mine last week, and it cost me $14.95 from Autozone and took me about 5 minutes to install. I'm not any kind of a mechanical person, but this is a really easy, no brainer, diy job. Hope this helps. I'm sorry, just reread your post, and my car is a 1999 Continental, so this info may be totally worthless, I don't know. Apologize again.
Posted by: xarruda89x
Can someone take pictures where its located and how to take it out? I'm the biggest n00b when it comes to under the hood work.
Posted by: gcwimmer
Open the hood, remove the push pins in the cowl above the fire wall, remove cowl and it is on the passenger side, replace or blow out filter, replace cowl and push pins. Close hood....Miller Time.
i can't recall off the top of my head but don't the wipers need to go up to remove the cowl?
Posted by: SoonerLS
To remove the pushpins, push down on the center pin until it clicks (less than 1/4"), then pull up on the outer ring of the pin. While you have the pin out, push the center pin up two clicks (so it stands proud of the outer ring), and you're ready to reinstall it by dropping the pin in place and pushing the center pin until it's level with the outer ring.
