if thats the case,,anybody know for sure??
so I cannot use this converter at all
if thats the case,,anybody know for sure?? |
Ah...... ok! i think i understand.
The 99 -04 stangs came with two different versions of the same engine!!! A windsor version... and a romeo version. Very different - some parts not interchangeable. One had a 6 bolt crank, the other had an 8. ![]() They explain it here: (all very confusing, with ford switching back and forth) http://www.mustangforums.com/m_4523011/tm.htm So, i guess you just gotta get the torque converter etc. for the 6 bolt application, right? Read post 17 of that link - very confusing! (although informative) I think you guys need the 6 bolt 'romeo' version stuff. Man, i gotta headache! Lol. I was just on a Mustang parts site, they do indeed list 6 and 8 bolt flywheels and stuff for 99 - 04 Mustang GTs http://www.americanmuscle.com/99-04-...flywheels.html |
1999-2000 Mustang GTs used an 8 bolt crank. That's because production capacity at Romeo was limited so Windsor engines were used. All Windsors use the 8 bolt crank as their production is mostly for trucks. '96-'98 and '01-'04 GTs used the 6 bolt.
Our Mark VIII engines had a 6 bolt crank. But, that's irrelevant. 6 bolt versus 8 bolt makes no difference for the torque converter - only the flexplate. The same 11.25" TC is used with with either crank. So to use one on either crank it's just a matter of using the correct flexplate. If for some reason you do need to change the flexplate to use this new TC, just remember 6 bolt. They are inexpensive. I'm unsure why you would have to, though - I purchased a new 'Mark VIII' converter from Ford and it was a match to the new 11.25" (10.5" bolt pattern) Marauder/Mustang/Mark flexplate I bought. BTW, the Mustang converter has nearly the same K factor and thus effective stall. Changing to it isn't really a performance upgrade, but you are still starting out with a newer TC. If you order a 11.25" TC service assembly for either the Mark or the 'Stang from the dealer you will get the same part ![]() |
Jelsoft Enterprises Limited.
