Has anyone checked with Torrie, Max etc? They all have access to locators...
i have seen references to the oil pans on these before, do they rust out and leak? when I go my 96, it had rust on the bottom of the pan and I sanded it lightly and sprayed it with engine paint-so far, so good, i don't have any leaks, but is this a common problem in rust states?
Yes.
I removed my oil pan, sanded every bit of rust off, and spray painted it with 3 coats, and baked the paint in. Dupli-color brand black engine enamel is what I used. It lasted about a year before it started peeling away. It's supposed to be good up to 500 degrees, but if it wasn't strong enough to stay on an oil pan, I don't see how that stuff can last on top of an engine, where the heat and other conditions are much more harsh. |
Got me very confused! Lol.
hrm.....
im pondering yanking that engine at the pick n pull even more now. got a good pan on it.... |
Jelsoft Enterprises Limited.
