yea do these newer trans have spots for my speedo cable gear? because arn't all the obd II stuff digital? is that what you guys are talking about the output shaft?
Ive heard that the mark viii trans are beefier than your run of the mill ford/ cars and trucks - that true? I mean the markviii was relatively expensive car! |
Abe, go to www.car-parts.com search for the 98 mark 8 trans.
I got one with 20,000 miles for $275.00 |
hey im on tccoa.. and reading about the 4r trans, and that the cobras and 99+ newer mustang gt's use 8 bolt Torque Converter Bolt Pattern and the Mark 8 uses the smaller patter of 6 bolts?
So how in the world do you bolt a 2002 trans up to a mark 8 motor if it only has 6 bolts and its designed for 8? |
hey i did as well also! i found a bunch with low milage for under 300 bucks... the thing is, is that after reading jerrry w's documentation it was stated that the 5.4 truck 4r70w offers the most durability...
Also it says to go with the most modern 4r70w to go with as possible. There is a few guys around me that have put 2002 mustang gt v8's into their cars so im stuck between the three choices, or if i had the money i would def run for geno's, darrin or BOC built trans' but i just dont have the cash for that. I just want to get the best trans possible, which i would assume would be the latest model with the lowest miles vs the hassle. The 98 requires repinning, i can handle that... But someone explained what is needed for the 2002 mustang and im assuming thats someting about a selenoid and changing the 7 tooth to 8 tooth? im not sure what a 99+ 5.4 truck trans will require? |
i'm not trying to be an ass here but you can handle repinning a 98+ tranny but just the other night in another post weren't you asking everyone here where you are supposed to put the tranny fluid in, and also you were trying to check the fluid with the car off?? i dont think i would go anywhere near a transmission if i was you. pay someone to do it.
The crank has 6 or 8 bolts. If you reuse your flexplate and a compatable converter(i.e. stock mark viii or mach 1) your fine.
umm im good at wiring... i just have no experience with automatics - look if i new it was going to make me look like a noob when i asked that i wouldn't have asked....
but so far ive switched up 02's, installed a window, installed a 150 shot wet kit in the mark, put in the walboro 255, new waterpump, new plugs, 160 degree T stat? just because i didnt know how to doesn't mean I shouldn't "go near a trans", it makes me ignorant.. and now that I know - its pretty amusing. But i learned just like with all the other stuff. And if you have a problem with that I dont know what to tell you, but laugh it up because come hell or high water i like doing this stuff myself and learning. Since this stuff isn't innate, you had to learn it from somewhere! Jeez! tuff crowd. I pride myself on the stuff ive done myself... and i appreciate the help from here! So thanks! |
You have done more then most have while learing.
But listen to those who have done it many times. XLRVIII and jamie97lsc have had every bolt off that comes off of these cars. Did you ever wonder why the trans is shot in the first place ? Listen learn and do it, good luck just keep in mind what your geting into by those who have done it more then once. No one here is pointing you in the wrong direction. There is no dumb questions...but some questions show your lack of experience thats all. |
I'm not 100% sure on this, but I think the actual manual lever can stay with the trans, just you have to swap over the sensor so you have the same type that originally came with the car.
As for the torque converter, don't use the GT unit. The 2V motors have more low-end torque and not as much high end compared to the 4V ones, so anything with the 4V motor gets a higher stall torque converter than the 2V motors do. In fact people with the 2V motors will swap their TC out for one from a mark, marauder, or mach1 to get the higher stall speed. If you use the mustang GT converter, your car will be a dog off the line. If you aren't having any problems with the one in your car, re-use that. If that one is messing up, get another converter out of another mark, marauder, or mach1. |
Jelsoft Enterprises Limited.
