'02? dont even waste your time, take it somewhere. its corroded in there and unless you want to take the whole arm out and bash on the back of the bearing, there is no hope.
i bought the part at autozone, its a temkin bearing. other than the 4 bolts, you only need to remove another 2 bolts (same size) to take off the caliper and rotor. I've had it all apart, sprayed it a lot, and tried 3 separate times with no luck. there is another thread here with pics that shows it apart. just search hub bearing. |
Done. I went to Napa, bought a wheel stud ($2.39) and a set of 4 locking lug nuts (I should have really had them anyway) and had it fixed in 1/2 hour thanks to highmilemikey's method. I didn't have a short enough socket so I took 2 box wrenches, a washer and a lug nut. I ruined the lug nut but I bought 4 more as mentioned above so it was no big deal. I just squired some oil on the back side and on the threads and went slow so I didn't break this one too. It took me longer to put the rotor and caliper back on than it did to install the wheel stud.
Jelsoft Enterprises Limited.
