The sensor is not cheap and the oil has to come out to do so. But its a very DIY project. Easy to get to.
ok , it should be safe to wait for the next oil change to replace it . Thats the compressor mounts most likely. thanks , i'll check them Never had to get a filter like it, not sure where to get one. |
Recommended filter: Motorcraft FL820S - available at most part stores and Walmart!
Why are you using 10W 30 oil? 5w 30 or 5w 20 is what is recommended by Ford. |
The "groaning" sound is probably the air suspension compressor. When they get some age on them, they start to sound labored. Mine does that too. The compressor will eventually fail. But I'm going to let mine go till it dies. They're expensive too and you have to take the whole front bumper cover off to replace them.
You can take out air compressor via plastic fender liner removal - much easier than taking bumper cover off, imo.
Jelsoft Enterprises Limited.
