my dads 94 mark viii's front pass. power seat controlls all work except for movement forward and backward..anybody know why this is?|
...lastly, how do do you access the front door woofers and tweeters?
You have to remove the whole door trim panel:
Carefully remove the switch panels from the door trim, and look for the screws/bolts (the fastener tabs are easy to break). Remove the cover that sits behind the door-open lever. Remove the little black (almost triangular) cover that sits by the mirror on the door. There's a screw behind the red & white light lens on the door, and bolt (8mm) near the door-open lever. When you get them unscrewed, lift the trim panel up and off the door. Be mindful of the wires if you choose to not disconnect them. |
Jelsoft Enterprises Limited.
