It might be a loose caliper bolt or aone lug has no splines left. iF it sounds like pots and pans then it is most likely your bolt I would check the lugs and caliper bolt.
My brothers cobra had a loud clunk whe turning and when I looked at it, it it was he lug had no splines left and his wheel would not tighten down. My ball joints were bad and would clunk also. Might want to jack it up and try and shake the wheel and see if anything is moving. They might have gave you the wrong pads does it do it when you start to stop?
When putting the new tie rods on, all you do is take off the nut that connects it to the hub, then hammer the base of the hub where the stud goes through while pulling the arm out.. once that is out, make sure you count the turns it takes to get the tie rod end off, then when you put the new one on make sure you do the same number of turns. If you dont it will most likely be screetching all the way to the alignment shop. its not very hard to do these. Just make SURE you COUNT THE TURNS to take the end off..
Not really starting and stopping unless changing from forward or reverse. For example I may hear a clunk as I start backing up and again when put in forward - but not really when braking, just when it starts moving.
When at a stop with brakes applied I can turn the wheel and make it knock right on que. The lugs should be fine, new hubs. Ball joints are new as of last spring. Everything in the front end is MOOG. |
Jelsoft Enterprises Limited.
