Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
electrical problem with the mark..
Posted by: LeadFoot357
here's the problem.. every once in a while when i start her up my left turn signal light will come on in the dash & when it does.. all the lights on the left side of the car get dim, my horn doesn't work, my windshield wipers go extremely slow and when i stop the car it starts bogging down & dies, if it doesn't die it bogs real bad when i continue driving. oh & the thick group of wires in the bumper on the drivers side.. if i tug on it a couple times the problem goes away, its driving me crazy also my keypad & unlock on the drivers side do not work at all... the lock button works fine & the passenger side locks & unlocks both doors fine.. anyone have any suggestions for either set of problems???
Posted by: Blenderhead
I would start by looking at that harness. You might have an intermittent short that goes away when you tug on the harness, or you might have a bad ground or something. As for the lock, that may or may not be related. Start by following that harness and finding the problem with the lights.
Posted by: unity
Did this car have a side impact accident?
Posted by: 98CobraStarLSC
if it is dying the car, your alternator is working its butt off. so i would start with finding what is drawing all that power.. You probably are Frying your alternator so it wont last long unless its new.. Just a precaution. Your parastitic draw is too great. Something is shorting itself out..
Quote:
no, just a front.. two deer, took out the light farthest on the driver's side and broke the mounts for the driver side headlights
Posted by: Staffamerica74
Quote:
There is your starting point, either take it back to where the work was done or do it yourself.
i think i may have found the problem... one of the rubber grommets in the floor wasn't completely sealed allowing water in.. which corroded a few wires under the carpet, i fixed those & that solved a few problems with my locks, keypad & courtesy lights & hopefully the headlights, thanks for the help
