I'm getting ready to rip the engine out of the 94 because of a leaky pan gasket, so here we go,
Oil pan gasket
oil/coolant gasket for the oil filter adapter
Front main seal
Rear main seal
Rear output shaft seal for a 97 Mustang GT T45
Rear output shaft Bushing
Input shaft bearing set
also the Nylon Orings that seal the high pressure line going to the P/S pump.
For s and giggles, What are the CV shafts running for the VIII
Price and availibility, I'll be calling you on the 16th to order everything.
Posted by: 94m5
Add a set of 8.8" 4.10 gears to that max.
Thanks.
Mike
Posted by: mrzeee
Hi Mike
Did I not send this to you already???? anyway....the output ext hsg bush is not available through ford. I listed the input shaft brg there is no set.
1 3L3Z-6710-AA GASKET 862 1 20.76 20.76
2 F6AZ-6840-AA O RING 938 1 9.37 9.37
3 F5AZ-6700-A SEAL AS 414 1 7.26 7.26
4 F4AZ-6701-A SEAL AS 414 1 13.79 13.79
5 F4ZZ-7052-A SEAL AS 163 1 12.74 12.74
6 -388897-S SEAL 143 2 1.41 2.82
7 -388898-S SEAL 133 2 1.22 2.44
8 M-4209-G410M RING & 1 198.00 198.00
Posted by: 94m5
thanks max, I'll be calling you the Monday after the 16th.
