Originally Posted by NYC LSC
Mine's right next to the defroster button, under the heater controls.
Originally Posted by mespock
Same here!!! 93 Mark VIII
Originally Posted by Jamler3
Yep... On the Gen-1 they had it next to defrost... The best thing was the car operated w/out it until you pressed it.
Originally Posted by brentalan
As Jamler said, I unconciously shut off the T/C after turning the engine over. In fact, I am looking for the buttons in other cars when I get in them after cranking the ignion
I wondered about that Gen1 thing, I can't recall any cars that, stock, came as opt-in on the T/C. Could Jamler's Gen1 been modified by a previous owner? |
Originally Posted by driller
Sorry bud, that's wrong.
The Gen 1 (93-96) models had the OPTION of traction control. It was a popularly equipped option however. The default for the traction control is ON. When the button(located next to the rear defrost button) is depressed with the traction control ON, a circuit to ground is completed which signals the traction control to be turned OFF and the button is illuminated when OFF signifying the traction control has been switched OFF. Likewise, when the button is depressed with the traction control OFF, a circuit to ground is completed which signals the traction control to be turned ON and the button illumination is turned OFF signifying the traction control has been switched ON. If the traction control is switched OFF and the ignition key is turned to OFF, the next time the vehicle is started and the ignition switch is ON, the traction control will default to ON. Clear?! ![]() |
Originally Posted by indust82
what's the advantages of driving with it off? I know the advantages of having it on. Does it help mpg or is it a power thing?
Excellent question. Most Gen 1 Mark VIII owners simply never switch it off.
But I make this challenge... from a dead stop, with the TC on and the OD on - floor it. Now repeat, but this time turn off the TC and turn off the OD - floor it. I know in my '93, it is a night and day difference, always has been, even when 'stock'. Somewhere, I have Tazzo readings that show the power difference. ![]() |
Originally Posted by Moes8
Holy crap.their is an actual power difference>?????
Originally Posted by BeatingU
So does this mean I'm lucky my 94 mark does not have traction control.
vBulletin Copyright ©2000 - 2009,
Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009
