Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Help some diagnostics Fron a newbie
Posted by: dannydoo
Hi..I just scooped up a 97 continental 80k miles.
Theres a few problems maybe you long time owners can help me pinpoint.
1> The diagnostic port wont work with the snap on scanner,no comunication.
I checked most fuses..Pulled the relay from under the hood it was good,theres a lil diode near the pcm relay,i didnt touch.
2>the rear bangs like theres a loose muffler dont seem to be wheel bearings,or muffler...Is there something common?
3>the message check traction control wont go away.
The compressor is LOUD AS HELL for the shocks.
There is a fuse that has absolutly no power to it... called ride control
Is there any other way to scan the car?
OH the gas guage didnt work...but after i pulled the pcm relay and restart it,it worked all the sudden.
And the rear shox seemed as if they wwere super sloppy until I pulled that relay also..
Sorry so long.... HELP
Posted by: ground_zero298
Rear banging is swaybar bushings, rubber wrap arounders on the sway bar.
My compressor is loud also, but it works.
Welcome to LVC!!
vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009 - Created by Stefan "Xenon" Kaeser
