If you've been running the ac when you noticed the wet floorboards then check to make sure the condensation run off from the evaporator is actually comming out of the drain and dripping onto the ground, not running back down the drain and back into the firewall to the floor
my suggestion would be to take a real close look at the window sill trim seals that sit long the glass at the bottom, when they dry out water runs down the glass and into the interior of the door, they usually cant drain fast enough when it gets bad and water backs up and runs out from between the door trim and the metal backing onto the floor, or perhaps the sun roof drains are clogged
| Gotta think it's a leaky windshield if it's rain water. Maybe the windshield was replaced in the past..? |
i will have to say that since you didnt seal behind the air cabin vent under the wiper cowl that is most likely the problem, i know you can get behind it, but, this is what you can do, take the wiper cowl back off, and cut around that vent, take it right out, clean where the base of it sat, then run a bead of seam sealer around the base of the vent and squish it back down in place, use a thick bead dont be shy no one can see it, i have done this to stop leaks in a few of my customers mark's, i took it off completely and sealed the flange itself then squished it back down, real hard, let the sealer squeeze out then take your finger and smooth out the excess with your finger around the flange as much as you can, getting behind it is very hard, thats why i say to put the sealer on the flange it will help get it behind the vent. try this, i bet your water leak goes away.
Jelsoft Enterprises Limited.
