Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Differential rebuild Kits
Posted by: 94m5
Hey guys,
The 94's Differential has WAY too much backlash (prolly caused by too many high RPM clutch drops), and needs to be rebuilt.
I have a set of 4.10s and a new trac-Lok already aquired, but want to know where all of you went to get your rebuild kit. I have found a few sets for standard 8.8's but nothing for IRS.
I'm assuming I can use one of those, but will need to buy the output shaft seals, and bearings.
Opinons?
Thanks guys.
Posted by: mespock
Do you still want the punkin from that 94?
Posted by: 94m5
Quote:
Yes, I would like to get that ASAP.
also, PM me your paypal account so I can get you some clams for those wires, and let me know what shipping will be on the punkin'
Posted by: Rich88LSC
Contact Max. He know wht is need and will give you a good price. I'm pretty sure the install kit is the same and a solid axle car and you just need bearings and seals for the axles which aren't to expensive.
Posted by: chickenviii
Quote:
Originally Posted by 94m5 View Post
Hey guys,
wel you better tell JD to knock it off, cuz i know you wouldnt do this
Posted by: driller
I used the regular rebuild kit and bought bearings and seals for the half shafts. I rebuilt the differential w/4.10s last to go in the '96 and added a clutch ring restacking the clutch pack for better results. I also used an F150 S-spring. You should be able to search TCCoA for details on this mod. You measure and reuse 1 of the old clutch rings to keep from having to buy 2 kits.
Posted by: Icarus
I used the regular FRPP kit as well (M-4210-B with pinion gear and carrier bearings, M-4210-A without,) and the M-4413-A for the IRS axle bearings and seals.
The last kit I mentioned is far cheaper than buying the IRS seals and bearings seperately...
Posted by: 94m5
Allright, Thanks guys.
More opinions welcome tho.
Mike
Posted by: mespock
I'll see what I can do... been busy... Hope to pull the engine and pumpkin soon.
Posted by: mrzeee
the M-4210-B is $81.60 LVC and the M-4413-A is 19.20 LVC plus shipping...all in stock. That would be all the brgs and seals for the IRS
Max
Hey Max I have heard the new trac loks come with side gears compatable with the IRS. Do you know anything about this? I'm debating waiting to find a IRS traclok to make it easier if I need to get into the rear again and am hoping I don't have to bother with that if Ford updated the new one.
Posted by: mrzeee
The M-4204-F288 is for live or IRS for the past 4 years or so. List $215.00 and LVC is 192.00
Thanks Max. You should her from me in the next couple of weeks.
Posted by: 94m5
M-4210-B, Does this include the shims?
Thanks max
Mike
Posted by: Icarus
It has the pinion and carrier shims.
Posted by: 94m5
Alright, Got all the parts on the way for a 3.90 install on the 94 over the Weekend.
I can't wait.
Flights:Loans:Loans:Remortgages:Mortgages
