not that simple, yes you can use the 98 trans but you cannot just bolt it in and you are done. the wiring is different on the harness so you have to repin the transmission. its been done by many, you can search it. the struts are a bolt in, nothing needed to be modified or what not , bolt right in.
vBulletin Copyright ©2000 - 2010,
Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2010
