did I do something to get everone mad at me? I posted a simple question about the click click my sunroof makes when it opens I have to help it wondered if I had to change motors or can I buy a gear or something
Posted by: sbcaprice305
Its probably due to the fact nobody know's the answer or you werent being specific enough. Details?
I make threads sometimes with no answers, it's normal .
Posted by: Jeffguy11
Id guess motor- i believe theres a little access panel further behind the sunroof above the rear seat so you could get a better look. It put my money on the motor being shot tho
So does it click constantly when going forward and backwards until it stops?
Or when you try to open it it just clicks and does nothing?
As jeff said take the rear s/r panel off above the rear seat on the headliner and see if thats were the noise is comming from/
Posted by: Psychostang
If you have to manually push the sunroof to get it to open, I'll be the motor is worn out.
Posted by: Markviiiedrea
Sounds like the plastic teath are worn out.
Posted by: MatthewDavid
I think you're little hamsters are dead and the only ones alive are eating the others... poor hamsters... maybe get a new motor to replace them and give them a proper burial... sorry too early in the morning for me
Posted by: Frat-man-du
Is it the ASC roof or Lincoln roof - both are stock (post a pic of the switch they are different).
ASC switches are notorious for going bad.
Posted by: Jeffintampa
If I help it the clicking stops and continues to move, but I always have to help the start, Also when it goes all the way open it continues to click does anyone have a shut off or limit switch?
Posted by: slickemhoundd
ill tack on, my moonroof does not have the midstop, if i put it to vent and put it down it just keeps on going to full open or vise versa.. any help?
mine still has the mid stop but to start from the mid start it clicks till I help it
Posted by: chickenviii
we need to know what roof you have (stock or not) where is the roof switch at? sounds to me like the track might be stripped right there
My Mark is 100% stock, the switch is inbetween the little light switches on the roof
I had the ASC in my first car and that thing was crap!
id open the inspection cover over your rear seat, drop the motor and check out the teeth on the motor and the track
