Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
(HELP) 93 mark VIII shifter stuck in park
Posted by: newguy
and it will only go out of park when I disconect the battery?????????ANYBODY??????? is there a sensor under the brake pedal that mite be bad or came out of ajustment
Posted by: Abbens
maybe it has an interclock solenoid?
Posted by: jamie97lsc
are you applying the brake before you try and shift?
Posted by: Frat-man-du
Brake safety switch could be bad, I had to replace one on my Wife's 00 Stang. It would fail to work on any incline, after rocking the car back and forth it would kick in and release the gearshift. Finally it failed 100%.
Posted by: crownvicjim
Man that sucks. I mean a lot can go wrong with a car, but that? lol. everything is good and you just cant get it in gear. Any way to bypass it?
Posted by: kustomizingkid
you could unbolt your center console and see if things are working right with the shifter itself.
Posted by: newguy
I thought this mite be a common promblem,or there is a switch for that,maybe under the brake pedal??like the brake light switch
Posted by: chickenviii
look for a broken wire at the brake light switch, and on most fords if you turn the key to the first position you can take it out of park then put it in neutral and start it from there
Posted by: newguy
Quote:
yes thats what I'm doing now,also my radio don't work,,but makes a cracking noise when I was sitting in the car last night(with the key off) reading my dealer bk
Posted by: newguy
It was just the fuse,,daaaaaaaaa
doooooooohhhhhhhhh
id rather see something easy go wrong
vBulletin Copyright ©2000 - 2009, Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009 - Created by Stefan "Xenon" Kaeser
