Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
2000 town car upgrade questions
Posted by: V-Tally
Hi I'm new to the forums and I had a couple of questions about getting a little more horsepower from my lincoln, I'm looking to increase the horsepower of my 2000 lincoln town car by about 50-75 horsepower and was wondering what would be the best upgrades for that. I have looked online to see if there are any upgrade parts but i could not find any. I was planning to do a true dual exhaust, high flow cats and mufflers, a cold air intake and possibly a computer chip. Could you possibly please tell me the horse power jumps that i could expect each one of these parts to make and where i may be able to get some of these parts. Thanks in advance. My lincoln is a 2000 lincoln town car with 81,000 miles, it is a signature series with the single exhaust.
Posted by: ground_zero298
I'm not a expert on TC, but I would think you might get 30-35 horse. You have the 16v 4.6? Mustang gt parts with the same moter might be the way to go.
Posted by: KBX500
4.6 Mustang parts are typically tuned specifically for the Mustang. The Panther cars, Crown Vic, Grand Marquis and Town Car, are much heavier and need to have power improvements that do not eat away at the low-end of the power band. A Mustang is lighter and requires less low-end power, therefore power improvements can be more focused on the mid-range and top-end, and they usually are. Almost any increase in mid-range or top-end takes a little something from the low-end, and that can work against you in a big heavy car.
There are hi-po parts available that cater more to our Panthers in terms of minimizing low-end losses when adding mid-range power. And of course there are ways to add low-end power only, also. For starting out new you really should check out www.crownvic.net. Some members there have made their Panthers into formidable performers and not wasted money on the wrong parts.
Be sure to keep in mind these old approximate rules of thumb.
A .10 second decrease in ET requires a 10 HP increase or 100 lb weight reduction. Essentially each 100 lbs removed equals a 10 HP increase.
A Town Car Sig Series is already about 250 lbs heavier than a 2000 Crown Vic, so you're already at a 25 HP disadvantage in terms of weight a stock 2000 CV.
Dual exhaust 4.6 engines in Panthers are typically rated at 10 to 15 HP versus single exhaust, but with that extra pipe, Ford retunes the computer for a slightly different power curve and changes the transmission shift points. Those additional changes are small individually, but added together you get a 10 to 15 HP bump. So just adding dual exhaust won't automatically get you that increase, although it will help, and is an essential step to take advantage of any additional power adders in the future. Cats and mufflers that flow more freely won't benefit you all that much until you've made significant increases in the amount of air being pumped through the engine, and then only at the higher RPM ranges. We're talking big bucks here. Realistically, how often and how long will you be able to realize that advantage ? Not much.
Adding Duals, a better air filter and intake tube set-up and a reprogrammed chip will get an increase that you can feel, but it will not turn your Town Car into a hot rod. To get a more satisfying driving experience you should consider some handling improvements, also. Like upgraded shocks, sway bars and tires. Those improvements you can take advantage of much more regularly than trying to add more raw horsepower. The aforementioned power adders and the handling improvements will provide the best value for the dollars spent and big fun all the time.
KBX
Posted by: Geezer
I couldn't agree more. I am putting on duals, modding the airbox, addco sway bars and when worn out new tires. A little more ooomph and a sweeter handling geezer mobile.
Posted by: V-Tally
Thanks kbx500, I really Appreciate the info, it's nice to see someone respond with good info, I'm not really trying to make it a hot rod, and I wanted to stay away from any direct engine modification, basically get a little more power out of my lincoln.
Posted by: buddylee
my upgrades :
Super Chips Mini Turner (shift pressure/points/fan) *****
washable fram air filter
removed air silencer
4 new cats
2 new mufflers
new fuel pump
20 inch wheels
New Front Coil Springs 20% stiffer spring rate.
All blinker/and all brake lights converted to LEDS
New Eagle eyes headlights
Stock CD Player (what is ford doing with tape decks in 2000 ??)
Chrome : B-pillars / fender trim / rocker panels
Posted by: mark0101
look at his car
http://www.cardomain.com/ride/274907/5
Posted by: KBX500
Your welcome V-Tally. I'll bet you could find a reputable salvage yard to get you a complete factory dual exhaust set up from a wrecked Town Car for a reasonable price. They last a long time so a used system should work fine. Finding someone to install it, if you aren't able to do it yourself, may be a challenge, though. After that an aftermarket chip to re-tune the computer can do wonders.
I have a set of Edelbrock IAS shocks, that I bought for my 2000 Grand Marquis just weeks before it was rear ended and totaled, that I'll be installing on my 1999 Town Car. I'm leaning towards an ADDCO sway bar set after that. I have a single exhaust and not sure if I'm up to swapping in duals, just yet. But, maybe in the fall.
KBX
Posted by: KBX500
"Stock CD Player (what is ford doing with tape decks in 2000 ??)"
They assumed that their main customers, the 65 to 85 year old, didn't have any CDs or even knew what they were. Typical.
KBX
Posted by: dRock95MarkVIII
Here are some good entry-level bolt ons that will make a nice impact:
Dual exhaust. A factory or factory-style (walker replacement) will give you a solid 15hp at the crank. You will also need the LH muffler and tailpipe hangers, p/ns here: www.p71interceptor.com/dualexhaust
For most, if they do not have it already this is the first modification.
***Mercury Marauder airbox and 80mm MAF. This is a drop-in replacement for your stock airbox, and has better airflow. This is a better option than the "CAI" kits as the Ford intakes ACTUALLY draw in cold air, unlike the rigged aftermarket setups. To use this on a Town Car the only modification required is drilling a hole on the airlid for the -02 external IAT sensor, and in the bottom w/ hole saw to hook up to stock inlet tract. The CV/GMQ/MM draw through front, rather than bottom. THe 80mm MAF is 10mm larger than your stock unit, and uses the same connector so no fooling with wiring.
***SCT custom computer reflash. Unlike the 'canned' tunes you would find with most handheld flashers, an SCT custom tune is tailored for your vehicle and configuration to optimize power and driveability to your preference. A premium fuel, 91 octane tune is recommended for best power (I do not suggest 93 tune if you travel, as 93 isn't available everywhere but AT LEAST 91 is)
The tune will come loaded on a flasher, there are a few models available but I recommend the xcalibrator2 for it's ease of use and user-end adjustability with reasonable price tag.
Lonnie, at www.blueovalchips.com has tuned many panthers, including his own Town Car, so knows how to tweak these for a safe reliable tune to increase power.
***The two above modifications must be completed at same time, or purchase another tune for your flasher if you decide to do the box/maf later. The 80mm MAF has a different air transfer function which requires computer tuning to correct PCM, note this to tuner when ordering.
Gears! The easiest way to get that land yacht moving is a steeper rear axle ratio. The factory 3.08s on most models are great for highway, but leave much to be desired off the line. 3.55 is my recommendation, steeper than this (3.73+) will require an aluminum or AMMC driveshaft due to resonance/driveline harmonics/vibration at higher speeds from the increased driveline speeds. 3.55 is an all around nice ratio, and you can stick with stock shaft.
Computer tuning recommended to adjust shift schedule, though not required. If you do this before the MM box and tune, just mention it to the tuner then and get it all done at once.
Ported plenum. www.ADTR.net sells a drop in replacement hi-flow ported plenums for 1996+ panthers (96-04 and 05+ style) These have shown impressive gains and seeing as it is a ported factory part it is a perfect fit.
An aftermarket mustang plenum could also be used, but you will need to tee one of the vacuum lines as the mustang plenum uses one less (no vac brake booster on them)
70mm throttle body. You can do this the same time as the plenum. This is a 5mm increase over stock, though it's gains are much debated. There are many options but the most cost effective is the Lincoln Aviator 70mm t/b. Can order here: www.adtr.net
Underdrive pulleys. Cheap, marginally effective but there is some gain. Use pulleys for 96-early 01 Mustang GT for your 00 Town Car. March or Steeda recommended, high quality. Stay away from "piggy back" pulleys
Of course there is much more you can do than that. Head over to Crownvic.net, and go to the high performance section. Read the stickied thread "MZT and popular bolt ons" for some info to get you going. Have fun!
Posted by: Geezer
Do the TC's need a different drive shaft also when switching to 373's? That is a huge disappointment if so as I really wanted those gears.
IDN Conversion Tool:Credit Cards:Refinance:Personals:Remortgages
