Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
ATT: 96-98 Mark VIII Owners, look inside.
Posted by: ONEBADMK8
SPECIAL FORCES TUNING SOFTWARE BRAND NEW IN BOX.
SNIPER TUNING SPECIAL FORCES SOFTWARE FOR 1996 -1998 LINCOLN MARK VIII.
Take advantage of our Spring Sale on this item.
The Special Forces software has been developed for stock to heavily modified vehicles equipped with the Ford EEC-V ecm for gas engines (96-current). That means just 1 part number covers all vehicles. There is no limit as to how many files you can create. You can even choose to use one of the dyno proven plug and play performance files!! Installation and use is quick and easy and can be used from pc or laptop runing Windows XP or Vista.
Adjustable Features Include: -Compression ratio -Low / High fan settings -Engine idle speed -Passive Anti Theft -Fuel Octane rating -Headers / exhaust -H / x pipe -Rear oxygen sensor delete -Trans shift points -Trans shift firmness -Engine rev limiter -Engine speed limiter -Tire height / speedo correction -Gear ratio / speedo correction -Air Fuel Ratio adjustments (richen/lean) -Spark advance (+/-)
Range Of Adjustment: -Supercharger (Roots & Centrifugal) -Turbocharger -Nitrous (wet & dry) -Injector size -Returnless fuel pressure setting -Mass Air brand / calibration -Intercooler type -Fuel pump type -UNLIMITED number of files can be created.
TOTAL CONTROL MEANS TOTAL POWER!
The price of the Special Forces software (Flash version) allows you to program 2 vehicles and you have the option to program additional vehicles with the purchase of Sniper Bullets.
ANY QUESTIONS? PLEASE CALL 856 456 3605 From 9 am to 6 pm est.
