Also my real problem is this wheel apparently cannot be properly aligned. (So I was told by the mechanic that aligned it. Either the Camber or the Caster cannot be adjusted. What is happening is the car vibrates so much that the passenger seat wabbles constantly. Also, the passenger side front wheel has been reformed to look like someone that has been beaten over the head and has numerous bumps and welts on the surface. Bothe the inside and the outside of the tire are grossly worn. Inside down to steel. HELP PLEASE! There has to be a way to correct this problem. I do already have a replacement knuckle but I am not sure if this will help at all. |
Jelsoft Enterprises Limited.
