Wiring harness (different and seperate from the "injector harness"...yes or no)
INJECTOR HARNESS (whats wrong with using the stock injector harness)
CUMPUTER (OBD1 with auto trans. not manual, therefore it can not be taken off of a cobra, because all cobras are manual, correct???)
THE MASS AIR METER (this has to be calibrated to the injector size, correct?)
THE MAP SENSOR. (does this have to be calibrated also to the injector size)
Dont list a site to go to. I have checked the other forums and really dont see clear answers to what im asking above about each one of these items.
PLEASE HELP. |
because in one-two months i am leaning towards the E303 cam. I have the cobra upper and lower intake manifold along with a 70 mm throttle body. You had told me in another thread that the real problem lies with the restrictive heads. So i have to save a few more bucks for a decent set of heads, THAT, WHILE IM DOING THE CAM, ill be in the area already and might as well change the heads. So just to cover myself in the future, should i go with some sort of major power adder, such as a supercharger, I will have the right set up for it.
SO right now i figure MASS AIR, which confuses me a bit still no matter how much i read, would be the best bet. I understand that the E303 cam is not an "extreme cam", but still with the addition of the heads, 24 lb injectors, uppper and lower manifold, and throttle body...... .... .... i just cant see the speed density takin it as well as the MAF setup will. SO i need to get a ecu harness to maf and computer. and-and maf calibrated for 24 lb injectors. along with a computer (preferably an "A9P") because the AUTOMATIC settings as opposed to the 5 speed are more aggressive supposedly. YES OR NO??????? And i can use the "existing" fuel injector harness even though im upping the injector size and changing the ecu harness for the MAF conversion? I think im making some sense. Some sense, maybe? ![]() thanks a lot dude |
++Leave the fuel injector harness alone.- got it!
++Dont bother installing the 24 lb injectors i got. check! ++Rid of the 70 mm throttle body that you told me on two occasions was oversized. I should look into maybe swapping with somebody for a 65, rite? So if i go with the maf set up. what combination of heads and cam would be good? Is your vehicle still air density? if so, what combination of heads and cam work well with the air density system? thanks man |
as far as the top end of the engine goes......what happens when you upgrade and leave the bottom end stock.
Top end is now tight compared to bottom end that has 110k and is 17 years old. What are the chances that i blow the bottom end? My mechanic laughed at me when i suggest heads and cam. The most He said he would suggest is a set of rockers as far as the internals go. What do you make of this logic. It kinda crushed the image of gt 40's with a decent cam and rockers. Should i be concerned of bottom end holding up, before i start researching this a bit more and spending money on a dream that wont hold up very long??? |
i have had the car for 6k miles now. Both oil changes, i was asked if it had been 3k already. The oil was extremely clean on both occasions. It burns nothing. So that along with the fact that top and bottom end have zero signs of any kind of leak lead me to beleive that it was well maintained along with the overall appearence outside and inside.
A compression test is a very good suggestion. Thank you. I have looked at the mustang forums and clearly see the top end modifications with the miles on the blocks. However, it just seems like it makes a lot of sense that if you modify the top end, of a block that has perfect compression, with 110k on it that there will most DEFINATELY be more stress on the bottom end. Its hard to comprehend that the bottom ends life span will NOT be effected. |
Jelsoft Enterprises Limited.
