i have read the thread thats tells me what wire but the only time it will turn on the amp is if it is unplugged from the factory amp. But the only way i get a signal to the line out converter is when the factory amp has power.
im pissed off man I have the same problem.
I just hooked the remote wire up to one of the fuses in the trunk, but now my amp is on all the time. and my battery is slowly draining unless I pull the fuse from my amp when i turn the car off. I NEED TO FIX THIS ASAP. |
most relays need +12v to turn on, ford amp turn on is only about +6v, so you would need a low voltage relay like the TR-4 that PGA2b posted
Jelsoft Enterprises Limited.
