Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Kooks Headers / O2 sensor issue?
Posted by: shagdrum
From Sean Hylands book:
Most header manufacturers place the oxygen sensor bung into the collector...Unfortunately, the collector on a long-tube header takes forever to get up to operating temperature. the engine operates in open loop until the oxygen sensor is up to temp, and even then, the sensor is so far away from the engine, much like a long distance telephone call. We have taken to moving the oxygen sensor up into one of the primary tubes, as close to the cylinder head as possible. while it is true that we only see one cylinder, the respons of the engine is much better, and drivability is much improved. Ford used this technique in the Contour SVT.
Has this been an issue with the Kooks headers? Has anyone who used these headers reported a drivability issue, or a loss of gas mileage (that wasn't just due to a lead foot)?
What has been the experience with the Kooks?
Posted by: MonsterMark
Quote:
I'm going to take a look at that issue.
Makes alot of sense to me.
I'm going to do an experiment over the next couple of days and get back to you.
Posted by: Joeychgo
I havent noticed anything. But when I put my headers on I did a number of other things at the same time so it's possible that I wouldnt notice.
Posted by: Eagle1
I just got my car back from a rebuild, and put the Kooks headers on. Unfortunately I also made some other upgrade changes at the same time, such as a dynomax exhaust, CAI, high flow cats, and chipped the motor, and I am still getting used to the change in the set up. Normally when doing modifications I prefer to do them one at a time and thus better sense what returns those mods do, or do not, give. But this time I was doing a remanufactured engine swap, and felt that as long as that was going to have to be done, I would do all the stuff I like at one time and save on the time and labor of a seriatim upgrade program. (As long as we have the motor pulled, what else can we do while we are in here!). I have not noticed the above issue so far, but I will look into it also and see what gives.
Posted by: shagdrum
Thanks! I look forward to reading what you find.
Posted by: shagdrum
Quote:
Yeah, I figured that would be the case for most people.
Posted by: shagdrum
Quote:
Yeah, I am thinkin I might need a new engine in the next year or so...might as well add headers while I am at it. Just wanna make sure I am not gonna hurt performance, drivability, or gas mileage.
I'd love to move the bung but I am going to be selling off the whole exhaust system anyway so why bastardize it.
But I will compare cold start up and the 'open loop' situation.
Be careful on mods if fuel economy, etc are at the top of the list.
Gears will hurt mileage, don't care what anyone says.
Converter will hurt mileage, don't care what anyone says.
Bigger injectors will affect driveability to a point.
Headers affect back pressure and will cost some low end to gain some middle and high end.
List goes on and on.
Posted by: shagdrum
Yeah, I ruled out gears due to gas. I may still install an LSD. These cars can't really stand to lose low end torque unless you can get out of that low end quick with gears and/or a high stall TC; both of which I have ruled out. So...what do you recommend? Shorties? Cat back? There is no smog or emissions testing here in Kansas (unless you are moving into the state) So I can gut the cats. Gettin this car to produce a little over 300 hp and 300tq would be enough for me (300 is a nice, round number, right? )
Still need to get back that Lincoln ride (that I switched from when I sold my Town Car); havin issues there...
What is your split City/Hwy driving?
I'd start there.
If mostly city, I'd do gears. Even without the posi. The car will just react better.
I think high stalls suck. They create too much slip and eat gas. Great for launching the car but that is about it. For everyday around town, they suck.
A chip is not a bad investment for a bit of a gain. Mostly comes in the form of a better trans shift. Not so slow and slippery.
A Cobra intake and exhaust will relaly help the middle and upper ranges. The black car pulls so hard on the top hard. The stock white '98 is not even close. But driveability is so much better on the stock white one.
You start doing lots of mods and you will change the character of the car for sure.
I'm ADDING weight to the black car with suspension and subframe reinforcements to stiffen it front to rear. Hope for a better weight distribution which should aid in handling.
Posted by: shagdrum
I live just outside of the city. I also travel to surrounding cities pretty often. So I do a good amount of Highway driving. Couldn't tell ya the split, but it is a large amount. I still wanna put in a posi. I might consider a mild gear change then, say 3.27 (car is a base Mark VIII), or 3.55. I originally wanted to do 3.73.
I've been thinkin about that...
Yeah, I was lookin into the intake, but it seems that it might be more trouble then its worth. This is for a 1996 Mark (Gen 1), and I haven't found too much info for swaps into Gen 1's. One post suggested there might be fitment issues (under the hood)? How much work is involved in putting that intake in? Does it hurt low end at all? Also, what do you recommend for exhaust? Gut the cats (for off road purposes only )? Don't wanna hurt low end torque here, as the car is an everyday driver.
I made a rear shock tower brace for the car, and have the front lower engine control brace on order. The front suspension has been completely rebuilt, and I have the parts to rebuild the rear suspension (just waitin for a good day or two). The car still seems rough to me, though replacing all the bushings in the rear may help that. How does sensor lowering the car affect it?
If you do alot of highway, you'll miss the 3.07's with their long legs.
If you do do gears, go with the 3.73's or don't bother.
Do a chip 1st or a dyno tune before screwing around with the intake. For the cash, I would do a dyno tune. Plus you get a neato piece of paper that says hp and trq.
I'd leave the cats alone. I haven't seen anyone pick up power. If you wanted to pull the heads, you could port match the exhaust and polish them. That would certainly help.
The braces are a good idea. The more the merrier with this chassis.
Lowering the car involves putting LESS pressure into the bags. Less pressure, lower level. This also means that the car has less ability to support itself over bumps and the suspension will travel alot more, wearing out the suspension and steering components sooner. I would also recommend a 4 wheel realignment if you lower the car. Also, before lowering, I would loosen all the bushings connected to the UCA and LCA's, and re-tighten after lowering.
Btw, which engine cradle brace did you get?
Posted by: shagdrum
super coupe performance
...didn't know there were others available
Posted by: shagdrum
Wouldn't that also mean a smoother ride?
IMHO, no. Some guys like the lower ride characteristics but understand that their is less pressure in the bag. It would be like putting a thinner or lighter spring on. The shock has to work that much harder.
I guess you could call floatier = smoother but the car and the suspension was engineered to perform optimally at the original factory ride height.
Posted by: Roadboss
The headers Kooks offers for our cars are mid-length and they perform very well on my car. I do not have a start problem. If you note they are about 4" from the collector flange, which gets them pretty close to the tube.
Posted by: shagdrum
Quote:
What about over all drivability? Low end torque? how are those affected?
Super coupe performance sells these, and this is what they say in the item discription:
The 3/4 length design will augment low end torque...
Also...
Because these headers are significantly longer length than the factory manifolds, they require Oxygen sensors with longer leads
Posted by: Eagle1
I did a little digging on some other forums, and found a nice write up by a lad that had modified his Miata with some headers and found all manner of frustration with bogging and lurching, especially when running cold. When he switched his sensor to a heated four wire unit, joy and performance both returned. Here is part of his write up. I am not sure if this is going to help you, but I can tell you that my header set up uses a heated sensor and it runs just fine.
__________________________________________________ _______________
Platinum/Zirconium dioxide oxygen sensors (1, 3, or 4-wire) require that they be heated to a minimum of 662°F before they will produce any output signal (below this critical temperature they behave as a fairly large value resistor), and need to be in the range of 975°F to 1200°F to be operating optimally. This creates a problem when the sensor is located too far from the exhaust ports, or relocated further "downstream" from the exhaust ports as is common with most if not all aftermarket headers designed for the early Miata. Heated O2 sensors (requiring 3-wires) were designed to keep the sensing element heated to it's optimal temperature--the 4-wire sensor adds the benefit of a dedicated output signal ground wire (1 and 3-wire sensors use the exhaust system as the signal ground path).
With my 4-2-1 OBX header (an unashamed clone of the Racing Beat 4-2-1 design) the O2 sensor is located over 18" further from the exhaust ports than with the OEM header. This means that at times of low engine output such as idling and low power acceleration the sensor's temperature can drop out of the optimal range, and even below the functional range--this results in the ECU thinking that the engine is running lean. The ECU then compensates for what it thinks is a lean mixture by making the air/fuel mixture richer (more fuel) to what is really an overly rich mix; causing bogging and at times an actual "flame out" as the over-rich mixture won't ignite.
Heated (4-Wire) O2 sensors overcome this problem by including a 12V electric heating element (#8 in this diagram) within the sensor. These heating elements (typically 25W or so) keep the sensor heated to 1100°F or and therefore smack in the middle of it's optimal operating range.
I hope this is useful to you in your searching for a solution.
Posted by: shagdrum
...I hope this is useful to you in your searching for a solution.
Thanks! That is helpful! If I remember correctly, the from to sensors on our car (before the cats) are the 4-wire ones, so we should be good.
Now, the only question I have is, how do these headers effect low end torque? As noted in my previous post (#17), they are supposed to "augment" low end torque. However, MonsterMark said in post # 8 of this thread:
Is that just his experience with these specific headers, or have others had this same issue?
If I am not gonna lose low end, I will get headers, otherwise, probably not.
Shag,
I haven't been able to find the dyno sheets where my opinion came from.
They definitely do make power. I just thought they moved the curve higher and farther down the revs.
Anything above 3000 rpms and you will be ahead of the game for sure. It was under 3000 that I was talking about.
For torque on the low end, you need scavaging. Headers are designed to create less back-pressure. And especially with cat deletes I can't see how that could help low end torque.
If anybody can post up something definitive, I'll concede the point but from memory and driving around, you definitely won't gain low end. Maybe at best keep it the same. Mid-range and upper end you will most certainly feel the motor pull harder, just like when you remove the stock mufflers for straight pipes or flows.
Posted by: shagdrum
Shag,
Was is a definite lose of low end torque, or mainly a large increase in the "above 3000 RPM" range that made the low end seem to lose some?
I trust your judgement, but I wanna make damn sure there is a big negative in an area I am concerned with (low end torque), before I rule headers out.
also, do you know of any mods to increase low end torque (besides a whole custom rebuild from the ground up)?
Thanks for all the inpt too, MonsterMark...
[quote=shagdrum;368939]also, do you know of any mods to increase low end torque (besides a whole custom rebuild from the ground up)QUOTE]
Well 4.6 4V aren't exactly torque monsters to begin with.
I know you were worried aboutgas mileage but some gears might be the answer. Even without a posi rear end. Some 3.73's will help the car feel peppier by getting it up into the powerband sooner. City mpg might actually get a bit better. Hwy will probably drop 2-3 mpg.
You can get a chip or do a jmod for some more tranny response.
Replacing the stock mufflers with some magnaflows or similar will make the car sound faster.
Posted by: shagdrum
Not too concerned with sounding faster.
I know OHC multi valve designs are notorious for bad low end torque. I just wanna maintain the low end I have or improve on it, as well as improve the mid and upper range RPM performance, and maintain drivability. Gears seem kinda like a half-ass solution; "get out of the low end as quick as possible to get to where the power is focused".
Either way, with the Mark being my only vehicle and a daily driver, mixed with my current financial situation (college student) i can't afford to get gears and lose the MPG's (thanks to the enviromental lobby).
Posted by: Roadboss
There is no real benefit to go with headers unless you plan on doing some additional mods that reap the benefit of headers. True dual exhaust along with a quality chip and tune will yeild more results and be easier on the wallet and "greener".
Posted by: shagdrum
I would be combining the headers with a new exhaust setup, and probably a chip.
Posted by: Eagle1
In general, the most cost efficient and reasonable (I do not say "easy" because putting on headers for many engines turns out to be a royal pita with lots of little tweaks and adjustments that were not anticipated) mods for modest horsepower and torque gains are associated with "breathing". If you diddle with the "inhale", you often will do still better with balancing some improvement to the "exhale".
And, to the extent you can, refine the programming to your chip to deliver a more efficient burn. You get a few ponies and lbs/ft. But only a few. There is some auditory satisfaction with the low down growl of a set of headers, and there is no denying that the rumble is most satisfying. It grabs a gentleman's attention the way a new pair of shoes in the window arrests the walk of most ladies. Fast, loud and shiny is just pre-programmed into the genes it seems. So, a nice high flow intake and filter, headers and cat back will usually do a good job....but unless you are prepared to go FI and/or build the motor, the driving experience is not really a huge change.
The key is always what really is it that YOU want out of your car, and why, and what does it do to the driving experience. Will it be a cost effective and reasonable thing for you to embark upon? You can take a Yugo and make it a rocket ship.........but why would you? (Not unlike Mark Twain remarking that the remarkable thing about a dog walking on its hind legs was not that it was done badly...but that it was attempted at all!)
The Mark VIII is a rather unusual bit of work for Detroit, a car that averaged about 20,000 units a year for six years...but in fact after a rather robust debut kind of trailed off, rallied briefly with Gen 2, then faded fast. It probably did not deserve to disappear so quickly given the quality of the car and its innovations, but for whatever reasons, and there are many, Ford did not stick with it.
You might be amused/bemused at the fact that the Mark VIII is almost the same wheelbase and curb weight as a............Infiniti G35 coupe!!!! (But about two feet shorter overall...the Mark has a heck of an "overhang" at both ends.) A very popular seller these days, but much less luxurious and still priced about ten grand below the debut price of the Mark VIII in '93.
What is remarkable about both cars is the powerplants. The aluminum block Tedsik cast 4.6L DOHC V-8 is really something, as is the Nissan 3.5L VQ35DE V-6. Both deliver very adequate power, and driven with discretion, decent gas mileage. You can bump the grunt by up to 40hp/tq with breathing mods and tweaks...and then you are about done. The Lincoln benefits from many of the innovations developed for the Mustang, while the G35 is favored by having the same block as the 350Z. For the money, it may or may not be worth it to you to do that breating upgrade to a car with the residual value these cars now have. You certainly will not recover it on resale, so it has to be for the joy of driving, and practical use you have for the car.
And so here is the real point....what do you want in the car and why. If you want a real performance return as a "driving" vehicle, then you probably don't want or have to do much to the motor at all. And certainly not the gears or differential. What you might consider doing instead is work on the handling of the car. But when you are done.....it won't be a "Lincoln" anymore. Put on some stiff Adco sways, some harder composition bushings, a coilover suspension, and wider wheels so you can fit some 255mm treadwidth a lower aspect ratio/stiffer sidewall tires all around for better grip, and you are set with a vehicle that will rip through a turn tight and flat. (No kidding, it will out corner a brand new Benz or Bimmer) And if you want to mountain/canyon drive you might even go with a BBK, though again the cost returns are probably not there for anyone other than a real driving enthusiast.
Before you spend a penny of your hard earned cash, think it through very carefully and develop a plan of what you want and need from your car, so you do not do and then undo mods, or have to redo parts as you move along with the plan. This is a very fine driving experience vehicle just the way it is for everyday driving.
I like the chip, headers and dynomax exhaust on my car, and it really shows up when you put your foot into it and it opens up at 65-100mph with a roar. My reflection is that the mid to upper range materially benefits from them, and the lower end may benefit slightly but probably does not suffer. So it is pretty much an "all good" thing to do. But the real fun for me is carving through turns and balancing the weight transfer with a modified suspension that just leaves the euro snobs in their $80,000 toys agape and falling behind. You need or should have some advanced driving school or racing experience to do that safely......but golly it sure is neat to do. It is one of the best looking and most comfortable sleeper cars out there.
Posted by: shagdrum
I am in this car for the long haul. Don't really plan on selling it anytime soon, so I might as well take the money I was thinkin of gettin a new car with, and invest it in improvements for this car. In fact, the reason I am looking at headers is because I may be replacing the engine soon (would be an easy install then).
I thought about doin the cobra intake, but it seems more trouble then its worth, and I can't find too much info for a swap into a 1996 (all the info seems to be for Gen 2 swaps).
Posted by: Eagle1
With the chip, CAI, headers, and high flow exhaust the car is delivering an actual 24-25mpg highway, at 70-73mph sustained cruising speeds, if that is a benchmark you can use against other combinations of mods for efficiency. This does also come with the wider 255 tires, which create greater rolling resistance and lower mileage.
Fast Loans:Payday Loans:Personal Loans:Unsecured Loans:Share Dealing
