Just had the same issue arrise with the AdvanceTrac light on the instrument cluster flashing. I also had a previous issue with the "Check AdvanceTrac" message randomly from the message center. This AdvanceTrac icon flashing happened recently, after having my transmission "diagnosed" at a shop. So I took it to a FLM dealer this morning to have the AdvanceTrac diagnosed properly. They pulled codes C1288 and C1289 from the system:
C1288 - Pressure Transducer Main / Primary Input Circuit Failure C1289 - Pressure Transducer Redundant / Secondary Input Circuit Failure They said there was a software update available and they just reflashed the transmission. Took care of the AdvanceTrac icon on the dash. Cost was $111.00. We'll see if this takes care of the intermittent "check advancetrac" message from the message center. |
vBulletin Copyright ©2000 - 2009,
Jelsoft Enterprises Limited.
vB Easy Archive Final ©2000 - 2009
