We had to retard timing 3* from the stock 10* advance. After the Snow N/A kit I was able to bump it back to 10* and eventually 4* past that with no pinging before I sold the car...new daddy had to lose some toys.
Zintkala is correct here. Meth can account for huge gains when cooling the aircharge in a boosted application where ACT's (IAT's) can run in the 200+ degree range but it really isn't worth it when running N/A while pulling ambient air. The higher octane you get from running meth injection is of a large benefit once again where you are on the borderline of detonation with a forced induction setup and need to bump the octane up to run more spark advance safely. Running really high octane whether it be in the form of racegas or meth injection into a N/A vehicle will hit a point of diminishing returns. If it didn't then everyone would be running around on 110unleaded racegas ($$$) in their N/A street performance vehicles. Some N/A vehicles will benefit from a touch more octane while other's will not. Allot of this has to deal with how the combustion chamber is designed in the heads in addition to the compression ratio. Meth is best a mod done in conjunction with a turbo or supercharger. You can use it like I believe Cammerfe did and run it in replacement of the fuel for a wet nitrous system but the jetting will be different due to meth having a much lower stoichiometric point than gasoline does. If you want a kick in the pants then I suggest getting a custom tune and full bolt-ons. If you want more power after that then the next step would be a wet nitrous system pulling regular fuel from your hardline. If you want more power after the nitrous then it will get expensive real quick. Good luck with things.
As ILLS says, I rejected the use of gasoline as part of the 'spray' package after setting the Maxton E/FSS record, and went to methanol. I'm not sure what the exact theoretical stoichiometric point is with the CH3OH---I'm told that it's about 6, but you can successfully run as rich as 4. I used three different pill sizes in E/FCC and went faster, the larger I got. I ran out of reasonable jets at that point.
I have since played with it on the street, by triggering the spray system without having the bottle open. You can feel it jump even at that, and I still have the pill in from the last run at Maxton. On the other hand, I doubt that it added any more than 10-15 HP and wouldn't be worthwhile as a stand-alone addition to a N/A vehicle unless you were running way too much compression and having trouble getting gasoline. KenS from Ben's Place |
Jelsoft Enterprises Limited.
