Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Upper Control Arms MKVIII=T-Bird?
Posted by: Hemihed426
I saw this asked on another forum and nobody had answered,wondering if any body knows the answer to this question. The Mark VIII control arm looks identical to the MN12 T-Birds except for the ball stud mount for the ride height sensor. If you have a coil conversion you obviously don't need the stud and there is about $30 difference in price. Does anybody know if the other dimensions and geometry are correct to be able to run the T-Bird arms on a MKVIII?
Posted by: slickemhoundd
Quote:
Ride height sensor spot on mark viii is the only difference, they will bolt up directly and yes with a coil over mark arms are not neccesary, even tho most argue mark viiis are mn12s
Posted by: 21stcenturygadgetguy
I was at Rich's house the other night, (Mespock) and he mentioned that! I think it is going to work fine, but maybe PM him, as I know he will know-
Posted by: Roadboss
TRW's at Advance = $58.74 ea
Posted by: vr4
Quote:
mark is an FN10 though many parts are shared with the MN12
The Mark VIII's are $83.14 at Advance. Thats an expensive little ball on there.
Posted by: mespock
I agree that little ball is expensive... But if you are ordering I always order one for a 96 T-Bird
gen 1s are mn12s and gen 2s are concidered fn10s, odd but true doesnt make sense but thru alot of research and head scratchin its what i came up with
Posted by: jamie97lsc
why would that be, the gen 1 and gen 2 under the sheet metal are the same exact chassis from 93-98 the only thing that makes it a gen 1 and gen two are some body cnages, not chassis changes all marks are mn12's
Posted by: 93' Blue on blue
Where did you get that info? Everywhere i have read says all Mark VIIIs were on FN-10. The Thunderbird is on the MN-12 and its not the same platform as a Mark, it is smaller.
The whole gen change didnt make sense as far as chassis (cause there wasnt) but i always concidered them all to be mn12s and still do but maybe because of all the mixed opinions thats what they came up with, and i also do recall a magazine (dont remember which) refered to the mark as an mn12, thats what i beleive regardless but everyone beleives differently
Posted by: vr4
http://en.wikipedia.org/wiki/Ford_FN10_platform
2006 ford motorsports catalog also lists the mark viii alone under the FN10 chassis code and the t-bird/cougar together under the MN12 platform.
FN=full size north america
MN=mid size north america
Posted by: Dawkins
has anyone accually done it with airbags...where did u mount the leveler...i dont need the leveler i could cut it off and use it for a paper weight...30 bucks is 30 bucks...NAPA Retail on the 96 tbird is $156(lifetime warrent.) $181 for the mark8...and theres about a $10 diff from left to right lol...
Posted by: Battery
If I recall correctly the fn-10 chassis is slightly longer.
Posted by: Sal329
I wish I could weld. I guess I have to buy the expensive ones.
Posted by: Sal329
Quote:
Does it make a difference with 3.8, 3.8SC or a 4.6?
