The part number I have found is 2W4Z8C607AA which shows to be a cooling fan and motor. However, I'm not sure if this is the hydraulic pump I need. In doing my searches on the part sites, I have found another part labeled hydrauic unit, which is more expensive than the cooling fan and motor. Basically my question is, Which part number and part do I need for the hydraulic cooling fan pump? Also, would it be an unwise decision to install a used one if I can find one? Have the new ones been fixed to correct the failures? And can a V8 pump be used on a V6? Prices and part numbers please. Thanks in advance
i have a leak also but i took it to the mechanic and we BOTH cant find where the heck it is im think it the water pump how much do u think that is???
another thing is that i dont kno what fluid goes in that damn resivor he said its power steering i said i dont really kno what it is maybe u can help. it just has a picture of a little fan thingy |
I have a 2000 LS V8 and I have a leak coming from the high pressure side of the pump. the is a metal bracket that holds it in place that has broken. Is that sold by itself or does it come with the hose. I called you guys today and left you a message also, but what I am wanting to know is how much the bracket cost or how much the hose cost if the bracket comes with the hose. I looked on the web-site, but I couldn't find it. Thank you for your helpl.
Jelsoft Enterprises Limited.
