What is the best way to clean the MAF sensor? Also what is the IDK?
With no CEL or trouble code, clean the MAF sensor as suggested above, and make sure it is facing the right way. You could disconnect the negative battery cable for ½ hr to reset the memory, and go from there.
A lot of good advice here. But also be careful not to over oil the K&N as the oil can foul the MAF sensor. But the big thing is to reset the computer by disconnecting the battery. I had to do this when I went to the KKM system.
| Don't they want to get warranty repairs dollars from Ford? |
| I would think they would have checked the plugs to make sure, but I did not see them check out my car. |
Jelsoft Enterprises Limited.
