Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Max, lumbar support question.
Posted by: Psychostang
Max, the drivers side lumbar support sheet on my 95 Mustang Cobra is trashed. Does Ford still make this? It is basically what the inflator bag sits against. If so, how much? Thanks
Andrew
Posted by: mrzeee
Hi Andrew
Do you see the part in this pic????
Unfortunately I don't Max. If you look at part #61018, it basically attatches to the lower half of that frame hole. Then the bag sits in between it and the seat foam/leather cover. When you inflate the bag, it pushes up against this support sheet and then protrudes out the front.
Posted by: mrzeee
Hi
That would be a part of the complete seat back cover and they are no longer available...sorry. I did try the colors on the locator.
Max
Max. This is not part of the seat back cover. It attaches to the frame. In order to get to it, you have to remove item 610C06, 611A08, and 60136 (pad & cover). Then you will see the support attached to the frame. It is held in by 2 metal rods, which are secured by 4 tabs (part of the frame). 2 on each side.
Posted by: mrzeee
Andrew
I am still working on this....some say that the bag has the rods to attach it to the frame and some say that shield is with the frame so ????? Ill keep checking for you. This pic is from the test system pages....all are generalized line art so they are really not accurate.
Max
Any news yet?
March 1st, any progress?
Posted by: mrzeee
The answers I recd did not help so I ordered one and will advise when it is here in the next day or so.
Posted by: mrzeee
ok it is here.....
The bag AKA adjuster is attached to the "sheet" that has a rod at either end that attaches to the frame. It is part number YR3Z-6365500-AA and has a list of $34.27 and will cost you $25.70 plus ups.
you can reach me directly at.....
Max Zuckerberg
Parts Specialist
Five Star Ford
7100 east Mc Dowell Road
Scottsdale AZ 85257
Direct 1-800-866-1520 ext 236
Fax 1-480-949-8478
parts@fivestarford.com
Posted by: mrzeee
Hi Drew...sorry I missed your call , I am heading out the door for the weekend so Ill talk to you monday. I have the part ready to ship just needed to ask you about it first.
Max
NO problem Max. I will call you on monday morning.
Max, part arrived yesterday. IT is exactly what i needed. Thanks again.
Posted by: mrzeee
Great news.....it was a hard road but we made it!!
Max
