If your going to take the time to swap them 4.10's with some kind of posi is the only way to go.
oh and yeah... 28 spline... You'd have a good deal of work ahead of you if you wanted to run 31-spline!
I didn't list the standard Mark numbers only the LSC (3.08 axle vs 3.27 axle).
I have no idea how many times this has been discussed but 4.10's, 4.10's, 410's.
I would have to argue this... it depends on what you're looking for. 4.10's are not the answer to everything. 3.08 to 3.73 is a healthy jump in ratio by itself.
If you go by the theory of "if you're gonna take the time to do it... go big" then why not just throw down on a set of 4.30's, 4.56's, or 4.88's? Hell, they make 5.18's for the 8.8 so if you're gonna do it, go all the way right? Believe it or not, there are some people out there who want to cruise down the highway a couple hundred miles everyday at 80 MPH and NOT have their relatively large displacement, entirely CAST engine spinning at just south of 3000 RPM (2751 RPM w/factory diameter tires to be exact). For reference, the reason those tiny V8's are able to rev so high is due to the lower weight of their reciprocating mass inducing much less stress on the connecting rods and crank I also don't agree with your posi statement (I'm about to split hairs... sorry... oh, btw... posi is a brand, not a type of diff... I know your implied meaning was limited slip). For some people, a limited slip is of almost no value and they want a locker... Yet for others, they have no need for a limited slip and just need to repair their rear-end and maybe get a bit more gearing advantage so they can tow their 3 million foot yacht. |
It is very easy for you to make this call yourself.. with your own car.
Get out on the freeway to your usual/desired cruising speed. The switch your OD off. The RPM's you are turning in 3rd gear w/307's is identical to the RPM's in 4th w/410's. Buddy of mine has a 410 car and we set our cruise controls while out on the freeway, then I switched off the OD and our RPM's were identical. So, get out and give it a shot and decide for yourself. Now with that said.. You will LOVE 410's in a city driving scenario, the car is much more responsive on the bottom end... you'll LOVE IT! |
IMHO 2900RPMs at 80MPH is well within my "tolerance level".
Then again, my non-overdrive(c-4 trans) mustang with 410's was turning close to 4K at 80... it would hit 6500 right at the finish line which was "right in the sweet spot". |
And that's the point... what is your tolerance level?
There are trade-offs to any gearing selection; factory 3.07's give you highway mileage and possibly a longer engine life. |
I wonder if my 245-50 and his 225-60's created the differences you are seeing in your math.
I know there wasn't "a measurable" amount of difference looking at the stock tachs which have been known to be quite a bit in error. 373's running on 245.50s are closer to a 390 gear than a 373 from what I have found. mathamatically you may be correct, but in a real world scenario 200RPM's is almost immeasurable on a stock tach. While this might not be accurate to the "inth degree" it will give someone a good "fair" amount of insight if 410's are "too much gear". comparing 373's to 410's is like a cup of coffee with 3 scoops of sugar compared to 4 scoops of sugar, one is definatley sweeter than the other, but not by a large margin. |
I put 373's in at 68,000 miles and took the original engine out of my car at 360,000 miles... additional wear didn't seem to be much of an issue.
Had my original engine not lost one of the cam chain tensioner pads {was still running) It likely would have easily made it to half a million miles! I've said it many times.. DO NOT FEAR THE GEAR! |
This is where you and I differ... You may have just had some freakishly good luck...
On a side note... with 360k already on the clock, I think I'd have been tempted to just keep running and see how long I could push it. What's the worst that could happen? Chain breaks or jumps off? Big deal... so you have to rebuild the engine (as if it wasn't starting to get a little worn anyway) and maybe replace a front cover. |
I totally agree... the tire size could make up for most of the difference, and the factory tach and speedo certainly are not test unit accurate!
Also agree on the last paragraph. In reality, it's a .32 difference; nothing monumental... but still a little noticeable. |
Hey Nate, you seem to be a person that likes to "crunch numbers".
take 2000 1/4 mile passes and 3000 1/8th mile passes and tell me how many miles of WOT that is? |
875 miles....
and I must say, if that engine got to 360k and did about 875 WOT miles (and we're talking acceleration miles, not top speed... which is even harder on the engine)... I'm impressed and I still stick to my guns; you got hella lucky with that engine!! |
dont forget how much it costs to install the gears once you have them. its not just oh let me buy some 4.10s and boom there in. its easily a thousand dollar purchase.
You're getting ripped off if you're paying a grand to have gears installed and set-up. It's routinely done around here for half of that....and that's including a new Ford Trac-Lok.
Jelsoft Enterprises Limited.
