Lincoln vs Cadillac Forums
Back to the Archive Main Page
Pages: 1
Startng Bid: $1 Ebay: "Sony Amp/1.25 Digital Cap"
Posted by: Sifrino3
Item number: 7943656135
Crutfield Price $199.99
Give your mobile audio system a shot of style and sound with a mono subwoofer amplifier from Sony. These amps give you more of what you want (like power, volume, and versatility) at a price that's easy on your wallet. And, with a Sony in your set-up, you're sure to get more attention — these stylish amps definitely have an extra edge when it comes to looks.
The XM-D500X uses an efficient Class D design with MOSFET power supply and output stages to give you the punch you need (up to 500 watts at 2 ohms) to create a truly outstanding audio system. And, with a variable low-pass filter to control the frequencies being sent to your speakers, and a variable bass boost (0-10 dB at 40 Hz) for plenty of low-end impact, you get the kind of sound-shaping control usually reserved for more expensive amps.
Key Features:
* 250 watts RMS x 1 at 4 ohms
* 500 watts RMS x 1 at 2 ohms
* 2-ohm stable
* Class D design
* Variable low-pass filter (50-300 Hz, 12 dB/octave)
* Variable bass boost (0-10 dB centered at 40 Hz)
* Speaker- and preamp-level inputs
* Preamp outputs
* Gold-plated connectors
* Requires a 4-gauge wiring kit — wiring and hardware not included with amplifier
* 15-5/16"W x 2-1/16"H x 10-9/16"D
10-day listing
Ends Jan-05-05 06:59:51 PST
Item number: 7943658766
Audio Price $189.99
Get the power and performance you never dreamed possible from your amplifiers!
Stiffening capacitors can help your amplifiers deliver up to 50% more output on those demanding peak bass notes. Most automotive alternator/battery systems simply lack the ability to produce large amounts of instantaneous power. This is exactly the type of power that car audio amplifiers crave. Adding a stiffening capacitor to your system can add tremendous bass punch and improve transient response.
Experience Tighter, Quicker and More Defined Bass! Most automotive alternator/battery systems lack the ability to produce the instantaneous high DC power your car audio amp craves! These high grade power caps store energy and then very quickly release it, on demand, to your power amp(s), resulting in a huge increase in bass punch and transient response. LED display shows the average cap voltage. Also features HQ Gold plated terminals and includes 2 brackets, hardware, wrench, resistor and manual with instructions.
Key Features:
* LED Voltage Display with Relay
* Capacitance: 1,250,000uF +/- 5%
* Operating Voltage: 10V-24V MAX
* Operating Temperature: 95C (200F)
* Power On LED Indicator
* Silver Finish
* Highest Quality Gold Terminals
* Mounting Brackets Included
* Install Manual and charging resistor also included
10-day listing
Ends Jan-05-05 07:09:23 PST
Posted by: Sifrino3
Five Days Left
Current Bid Amount;
Reciever Bid: $31.00
1.25 Cap Bid: $1.00
Posted by: Sifrino3
20 Hours & Counting!
Sony Amp: $41.00
1.25 Farad Cap: $10.50
Posted by: ModPWR
Where did you get that shipping quote from ? I'd bid, but not with $18.25 to ship both small and not very heave item.
Posted by: Sifrino3
Quote:
Where do you live? It is a flat charge to ship any where. . .
Posted by: ModPWR
Quote:
48212 , fedex or ups preferably. Let me know, J.
Posted by: Sifrino3
E-mail
Car Insurance:Loans:Credit Card Consolidation:Mortgage Calculator:Ajax Script
