shifter light isnt hard to replace, just pop the cover off and there are 2 bulbs in there I think if have sst. the bulbs can be found at any car parts store.
A wee bit more to it than this. The center console needs to come up, which simply means the ashtray/heated seat trim needs to be popped off, then the console lifted up and off. Traction Control plug needs to be unplugged from switch for the console to come completely off. The shift bezel may need to be taken off, or at least lifted up for room. The bezel pulls straight up and unsnaps from it's holders. You should then be able to twist the bulb housing counterclockwise, pull out, and replace bulb.
"Mines"-Only used when describing multiple explosive devices or multiple places where diamond and coal are obtained.
The only thing i dont like is that the gas and trunk buttons do not have lights.....
Jelsoft Enterprises Limited.
