Originally Posted by lboy1971
My mother has kept nagging at me to get her 91 town car running for a couple years now. First the air bags went flat and wouldn't pump up. I ended up removing them and installing a metal spring conversion kit. Second, shortly after doing that the rear end went out and chewed up the ring and pinion gears. Found a used axle from a Crown Vic and installed it.
Now the car won't turn over. If I jump the selonoid with the key in the "run" position it'll start and run good. The selonoid won't "click" when just trying to start the car with the key. The selonoid is mounted on the fender next to the battery. The car did this a few times last year but went away. Now it won't start at all on it's own. Also, the corner parking lights keep flashing along with the dash lights. There is also a small red light on the dash left of the steering column in the middle of the long horizontally running trim peice that keeps flashing but not in time with the parking and dash light flashing. The little red light has flashed the whole 2 years she's owned the car. There's nothing next to the light to say what it's for and the owners manual doesn't show or mention it at all. Any help in getting this, eh hem "LEMON", running would be greatly apreciated, thanks Lloyd |
Originally Posted by HizHonor
First, the red light flashing is telling you that your auto lamps are on.
Originally Posted by Dereck
Hi HizHonor
I don't think the autolamp warning light came in until '94 Regards Dereck |
Jelsoft Enterprises Limited.
